    Sentences not loaded in hello-Lucy
    19 Posts 2 Posters 2.7k Views 3 Watching
    • N Offline
      Nicodil @sdetweil
      @sdetweil Yes, i posted it in both folders, to get sure:
      • N Offline
        Nicodil
        It looks like it is reading now the sentences.json. Im not sure why, the error was not shown anymore after a few restarts and changes.
        BUT still Lucy understands only nonsence, only the words in the words.json…
        The Array of the sentences is there, like in your picture, so it is read.
        She still cannot understand “Show modules” or “Hide Modules”, only words like “the”, “who” , …
        Any idea?
        • N Offline
          Nicodil
          @sdetweil Your changes creating some errors for some reason. Exactly the same line (15):
            sdetweil @Nicodil
            @nicodil Mykle has updated the repo
            so you can git pull to update
            but u need to restore the file first
            in the module folder do
            git checkout HelloLucy.js
            then
            git pull
            • N Offline
              Nicodil @sdetweil
              Hi @sdetweil ,
              im sorry to say that but this is an error after the Update.
                sdetweil @Nicodil
                @nicodil ok, so you will have to go into the developers window to help me
                ctrl-shift-i
                select the sources tab
                find the module in the left nav, and Hello-Lucy.js
                and click the number on the left column
                for line 15 var sfn=
                then hit f5 refresh
                it will stop at line 15, then using the mouse hove over the .src of document.currentSrc.src
                take a screen shot of that
                • N Offline
                  Nicodil @sdetweil
                  @sdetweil said in Sentences not loaded in hello-Lucy:
                  Thanks for your time and help!
                    sdetweil @Nicodil
                    @nicodil ok, then tap the button next o the blue arrow >
                    then hover over sfn
                    then put stops on line 9 and 22 and hit run (blue arrow)
                    • N Offline
                      Nicodil @sdetweil
                      It works fine when i dont load the RemoteControl, no error -Module… But the error with the RemoteControl is pointing to line 15, thats strange…
