    SD Card - Full
    5 Posts 2 Posters 1.3k Views 2 Watching
    • G
      George
      Hi, I have a problem. The mirror starts very slowly, sometimes it crashes, sometimes it does not restart with “sudo reboot”. I assume the SD card is full. I don’t know how to check.
      I don’t know how to edit the config.js and remove debug from the logLevel list. I asked this in a post “SD Card - no Space” and the answer was a link.
      Does anyone have the time and patience to explain in detail all the steps to solve this problem?
      Thanks,
        sdetweil @George
        @george how do you edit config.js to add a module?
        df -k
        will show u disk usage
        the pm2 flush command will empty the logs
        • G
          George
          @sdetweil , how I edit config.js to add a module:
          config folder: Open
          config.js: Open
          config module: Paste
          So, I opened a terminal in Config folder, df -k command, I sow, the SD is full 95%.
          I wrote in this terminal “pm2 flush”, I tried also “sudo pm2 flush” and the answer was “command not found”.
          In which terminal do I have to type this command?
            sdetweil @George
            @george sounds like u are not using pm2 to manage your mm execution
            config.js: Open
            so when u open config.js there is a line above modules:[
            logLevel
            edit that per the instructions
            if it’s not there add it, and make it look like as written
            G 1 Reply Last reply
            • G
              George @sdetweil
              @sdetweil , I have no idea what I’m using. The software was installed by my son, I only know how to install and configure modules :(
