    Google tts
    1 Posts 1 Posters 311 Views 1 Watching
      sdmydbr9
      Has the google tts module stoped working or is it just me. I’m having trouble getting it to work. Here is my debug
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.14.11
      3 info using node@v10.24.0
      5 info lifecycle magicmirror@2.13.0-develop~prestart: magicmirror@2.13.0-develop
      6 info lifecycle magicmirror@2.13.0-develop~start: magicmirror@2.13.0-develop
      7 verbose lifecycle magicmirror@2.13.0-develop~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.13.0-develop~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.13.0-develop~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.13.0-develop~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 info lifecycle magicmirror@2.13.0-develop~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.13.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      12 verbose stack spawn ENOENT
      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack     at ChildProcess.emit (events.js:198:13)
      12 verbose stack     at maybeClose (internal/child_process.js:982:16)
      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      13 verbose pkgid magicmirror@2.13.0-develop
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 5.10.17-v7l+
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      17 verbose node v10.24.0
      18 verbose npm  v6.14.11
      19 error code ELIFECYCLE
      20 error syscall spawn
      21 error file sh
      22 error errno ENOENT
      23 error magicmirror@2.13.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.13.0-develop start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
      I have zero knowledge to debug this issue, someone please look into this and let me know of a solution if there is any.
