    Calendar module debugging
    1 Posts 1 Posters 385 Views 1 Watching
    • L Offline
      logan_13
      I’m trying to debug an issue with my Outlook.com calendar. I’m using MagicMirror 2.15.0.
      I tried to run:
      ~/MagicMirror/modules/default/calendar $ node debug.js
      but it failed with the following error:
      internal/modules/cjs/loader.js:883
        throw err;
      Error: Cannot find module 'logger'
      Require stack:
      - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
      - /home/pi/MagicMirror/modules/default/calendar/debug.js
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
          at Function.Module._load (internal/modules/cjs/loader.js:725:27)
          at Module.require (internal/modules/cjs/loader.js:952:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:13)
          at Module._compile (internal/modules/cjs/loader.js:1063:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
          at Module.load (internal/modules/cjs/loader.js:928:32)
          at Function.Module._load (internal/modules/cjs/loader.js:769:14)
          at Module.require (internal/modules/cjs/loader.js:952:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
          '/home/pi/MagicMirror/modules/default/calendar/debug.js'
      Any idea what I might be doing wrong?
