    Error: MagicMirror will not quite
    2 Posts 2 Posters 654 Views 3 Watching
    • E
      e199504
      Hello,
      I have installed MM from here
      When I want to run the Magic Mirror, I am getting the following error
      "MagicMirror will not quit, but it might be good idea to check why this happened. Maybe no internet connection? "
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.15.0 start
      > ./run-start.sh $1
      [10.05.2021 10:27.27.904] [LOG]   Starting MagicMirror: v2.15.0
      [10.05.2021 10:27.27.912] [LOG]   Loading config ...
      [10.05.2021 10:27.27.924] [LOG]   Loading module helpers ...
      [10.05.2021 10:27.27.928] [LOG]   No helper found for module: alert.
      [10.05.2021 10:27.28.211] [LOG]   Initializing new module helper ...
      [10.05.2021 10:27.28.212] [LOG]   Module helper loaded: updatenotification
      [10.05.2021 10:27.28.214] [LOG]   No helper found for module: clock.
      [10.05.2021 10:27.29.096] [LOG]   Initializing new module helper ...
      [10.05.2021 10:27.29.098] [LOG]   Module helper loaded: calendar
      [10.05.2021 10:27.29.100] [LOG]   No helper found for module: compliments.
      [10.05.2021 10:27.29.101] [LOG]   No helper found for module: weather.
      [10.05.2021 10:27.29.140] [LOG]   Initializing new module helper ...
      [10.05.2021 10:27.29.141] [LOG]   Module helper loaded: newsfeed
      [10.05.2021 10:27.29.142] [LOG]   All module helpers loaded.
      [10.05.2021 10:27.29.281] [LOG]   Starting server on port 8080 ...
      [10.05.2021 10:27.29.303] [LOG]   Server started ...
      [10.05.2021 10:27.29.305] [LOG]   Connecting socket for: updatenotification
      [10.05.2021 10:27.29.306] [LOG]   Connecting socket for: calendar
      [10.05.2021 10:27.29.308] [LOG]   Starting node helper for: calendar
      [10.05.2021 10:27.29.309] [LOG]   Connecting socket for: newsfeed
      [10.05.2021 10:27.29.310] [LOG]   Starting node helper for: newsfeed
      [10.05.2021 10:27.29.311] [LOG]   Sockets connected & modules started ...
      [10.05.2021 10:27.29.683] [ERROR] Whoops! There was an uncaught exception...
      [10.05.2021 10:27.29.697] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
          at Server.setupListenHandle [as _listen2] (net.js:1313:16)
          at listenInCluster (net.js:1361:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080
      [10.05.2021 10:27.29.700] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [10.05.2021 10:27.29.701] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [10.05.2021 10:27.29.748] [LOG]   Launching application.
        sdetweil @e199504
        @e199504 did u say yes to pm2?
        then pm2 is already running mm.
        do
        pm2 status
        then
        pm2 stop all, or 0, or the name shown in the pm2 status command output
