    i want to put my code in modeul
    5 Posts 2 Posters 404 Views 2 Watching
    • 김 Offline
      김윤호
      i have open cv phython code, and it is working very well without MagicMirror,
      but i want work this open cv in MagicMirror, what i have to do? replace ? change? fix?
      i have two code abuot basic MaigcMirror code, this open cv code.
      i want to put this code in MagicMirror and use this in MagicMirror
      please teach me in details.
      i am going to use MMM-Face-Reco-DNN
      import cv2
      import numpy as np
      import sys
      from PyQt5 import QtCore,QtGui
      from PyQt5.QtWidgets import QPushButton,QWidget,QGridLayout,QLabel,QApplication
      from PyQt5.QtCore import QThread
      import os
      import time
      casc='haarcascade_frontalface_default.xml'
      eye_cas='haarcascade_eye.xml'
      faceCascade=cv2.CascadeClassifier(casc)
      eyeCascade=cv2.CascadeClassifier(eye_cas)
      cap=cv2.VideoCapture(0)
      ret=cap.set(3,240)
      ret=cap.set(4,180)
      images=[]
      for i in range(1,19):
      images.append('./images/'+str(i)+'.png')
      print(images)
      num=0
      class MyApp(QWidget):
      def __init__(self):
          super().__init__()
          self.initUI()
      def initUI(self):
          global images
          grid=QGridLayout()
          self.setLayout(grid)
          self.btn1=QPushButton('1')
          self.btn2=QPushButton('2')
          self.btn3=QPushButton('3')
          self.btn4=QPushButton('4')
          self.btn5=QPushButton('5')
          self.btn6=QPushButton('6')
          self.btn7=QPushButton('7')
          self.btn8=QPushButton('8')
          self.btn9=QPushButton('9')
          self.btn10=QPushButton('10')
          self.btn11=QPushButton('11')
          self.btn12=QPushButton('12')
          self.btn13=QPushButton('13')
          self.btn14=QPushButton('14')
          self.btn15=QPushButton('15')
          self.btn16=QPushButton('16')
          self.btn17=QPushButton('17')
          self.btn18=QPushButton('18')
          self.btns=[self.btn1]
          self.btns.append(self.btn2)
          self.btns.append(self.btn3)
          self.btns.append(self.btn4)
          self.btns.append(self.btn5)
          self.btns.append(self.btn6)
          self.btns.append(self.btn7)
          self.btns.append(self.btn8)
          self.btns.append(self.btn9)
          self.btns.append(self.btn10)
          self.btns.append(self.btn11)
          self.btns.append(self.btn12)
          self.btns.append(self.btn13)
          self.btns.append(self.btn14)
          self.btns.append(self.btn15)
          self.btns.append(self.btn16)
          self.btns.append(self.btn17)
          self.btns.append(self.btn18)
          self.btns[0].clicked.connect(self.cbtn1)
          self.btns[1].clicked.connect(self.cbtn2)
          self.btns[2].clicked.connect(self.cbtn3)
          self.btns[3].clicked.connect(self.cbtn4)
          self.btns[4].clicked.connect(self.cbtn5)
          self.btns[5].clicked.connect(self.cbtn6)
          self.btns[6].clicked.connect(self.cbtn7)
          self.btns[7].clicked.connect(self.cbtn8)
          self.btns[8].clicked.connect(self.cbtn9)
          self.btns[9].clicked.connect(self.cbtn10)
          self.btns[10].clicked.connect(self.cbtn11)
          self.btns[11].clicked.connect(self.cbtn12)
          self.btns[12].clicked.connect(self.cbtn13)
          self.btns[13].clicked.connect(self.cbtn14)
          self.btns[14].clicked.connect(self.cbtn15)
          self.btns[15].clicked.connect(self.cbtn16)
          self.btns[16].clicked.connect(self.cbtn17)
          self.btns[17].clicked.connect(self.cbtn18)
          for i in range(18):
              self.btns[i].resize(24,24)
              self.btns[i].setIcon(QtGui.QIcon(images[i]))
              self.btns[i].setIconSize(QtCore.QSize(24,24))
          grid.addWidget(self.btns[0],0,0,1,1)
          grid.addWidget(self.btns[1],0,1,1,1)
          grid.addWidget(self.btns[2],0,2,1,1)
          grid.addWidget(self.btns[3],0,3,1,1)
          grid.addWidget(self.btns[4],0,4,1,1)
          grid.addWidget(self.btns[5],1,0,1,1)
          grid.addWidget(self.btns[6],1,1,1,1)
          grid.addWidget(self.btns[7],1,2,1,1)
          grid.addWidget(self.btns[8],1,3,1,1)
          grid.addWidget(self.btns[9],1,4,1,1)
          grid.addWidget(self.btns[10],2,0,1,1)
          grid.addWidget(self.btns[11],2,1,1,1)
          grid.addWidget(self.btns[12],2,2,1,1)
          grid.addWidget(self.btns[13],2,3,1,1)
          grid.addWidget(self.btns[14],2,4,1,1)
          grid.addWidget(self.btns[15],3,0,1,1)
          grid.addWidget(self.btns[16],3,1,1,1)
          grid.addWidget(self.btns[17],3,2,1,1)
          self.setWindowTitle('set image')
          self.show()
      def cbtn1(self):
          global num
          num=1
          self.close()
      def cbtn2(self):
          global num
          num=2
          self.close()
      def cbtn3(self):
          global num
          num=3
          self.close()
      def cbtn4(self):
          global num
          num=4
          self.close()
      def cbtn5(self):
          global num
          num=5
          self.close()
      def cbtn6(self):
          global num
          num=6
          self.close()
      def cbtn7(self):
          global num
          num=7
          self.close()
      def cbtn8(self):
          global num
          num=8
          self.close()
      def cbtn9(self):
          global num
          num=9
          self.close()
      def cbtn10(self):
          global num
          num=10
          self.close()
      def cbtn11(self):
          global num
          num=11
          self.close()
      def cbtn12(self):
          global num
          num=12
          self.close()
      def cbtn13(self):
          global num
          num=13
          self.close()
      def cbtn14(self):
          global num
          num=14
          self.close()
      def cbtn15(self):
          global num
          num=15
          self.close()
      def cbtn16(self):
          global num
          num=16
          self.close()
      def cbtn17(self):
          global num
          num=17
          self.close()
      def cbtn18(self):
          global num
          num=18
          self.close()
      app=QApplication(sys.argv)
      ex=MyApp()
      app.exec_()
      print(num)
      num=str(num)
      while True:
      ret,frame=cap.read()
      frame=cv2.flip(frame,1)
      gray=cv2.cvtColor(frame,cv2.COLOR_BGR2GRAY)
      faces=faceCascade.detectMultiScale(
      gray,
      scaleFactor=1.1,
      minNeighbors=5,
      minSize=(100,100),
      sz=0
      a,b,c,d=0,0,0,0
      x,y,w,h=0,0,0,0
      count=0
      for (x,y,w,h) in faces:
          if w>sz:
              sz=w
              a,b,c,d=(x,y,w,h)
              count=count+1
      if count>0:
          if True:#눈이 발견된경우
              #cv2.imshow('video',frame)
              hair_url='./images/'+num+'.png'
              hair=cv2.imread(hair_url,cv2.IMREAD_UNCHANGED)
              height,width,channel=hair.shape
              origin_ratio=int(w/h)
              height=origin_ratio*width
              ratio=int(width/w)
              height=int(height/ratio)
              width=int(width/ratio)
              if w>0 and h>0:
                  if int(num)>15:# 선글래스 합성#
                      print('3channel')
                      height=int(height/3)
                      y=y+int(height/2)
                      x=x-int(width/12)
                      hair=cv2.resize(hair,(width,height),interpolation=cv2.INTER_AREA)
                      cut_img=frame[y:y+height,x:x+width]
                      gray_hair=cv2.cvtColor(hair,cv2.COLOR_BGR2GRAY)
                      gray_hair=cv2.bitwise_not(gray_hair)
                      ret,mask=cv2.threshold(gray_hair,100,255,cv2.THRESH_BINARY)
                      #cv2.rectangle(frame,(x,y),(x+width,y+height),(0,2,255),2)
                      mask_inv=cv2.bitwise_not(mask)
                      fg=cv2.bitwise_and(hair,hair,mask=mask)
                      bg=cv2.bitwise_and(cut_img,cut_img,mask=mask_inv)
                      result=cv2.add(fg,bg)
                      frame[y:y+height,x:x+width]=result
                      cv2.imshow('result',frame)
                  else:# 머리합성
                      r,g,b,a=cv2.split(hair)
                      r=cv2.bitwise_and(r,r,mask=a)
                      g=cv2.bitwise_and(g,g,mask=a)
                      b=cv2.bitwise_and(b,b,mask=a)
                      hair=cv2.merge((r,g,b))
                      height=height*2
                      width=width*3
                      if x>int(width/2) and y>int(height/2):
                          x=x-w
                          y=y-int(h/2)
                          ret,mask=cv2.threshold(gray_hair,10,255,cv2.THRESH_BINARY)
                      else:
                          print('step back too close')
      if cv2.waitKey(1)&0xff==ord('q'):
          break
      cap.release()
      cv2.destroyAllWindows()
      import cv2
      import numpy as np
      import sys
      ret=cap.set(3,240)
      ret=cap.set(4,180)
      while True:
      num=input('input numbers 115= hair, 1618 = glass')
      if int(num)>0 and int(num)<19:
      break
      while True:
      gray,
      scaleFactor=1.1,
      minNeighbors=5,
      minSize=(100,100),
      sz=0
      a,b,c,d=0,0,0,0
      x,y,w,h=0,0,0,0
      count=0
          if w>sz:
              sz=w
              a,b,c,d=(x,y,w,h)
              count=count+1
      if count>0:
          (x,y,w,h)=a,b,c,d
          roi_gray=gray[y:y+h,x:x+w]
          roi_color=gray[y:y+h,x:x+w]
          eye=eyeCascade.detectMultiScale(roi_gray)
          cv2.rectangle(frame,(x,y),(x+w,y+h),(0,255,0),2)
          sz=0
          count=0
          eyes=[]
          for ex,ey,ew,eh in eye:
              if ey<int(h/2) and ew>sz:
                  sz=ew
                  a,b,c,d=(ex,ey,ew,eh)
                  count=count+1
                  eyes.append((a,b,c,d))
          eyes.sort(reverse=True)
          if count>1:#눈이 발견된경우
              xi,yi,wi,hi=eyes[0]
              xxi,yyi,wwi,hhi=eyes[1]
              lx=0
              ly=0
              rx=0
              ry=0
              if xi<int(w/2):# xi : left
                  lx=x+xi+int(wi/2)
                  ly=y+yi+int(hi/2)
                  cv2.line(frame,(lx,ly),(lx,ly),(255,255,0),8,cv2.LINE_AA)
              else :
                  rx=x+xi+int(wi/2)
                  ry=y+yi+int(hi/2)
                  cv2.line(frame,(rx,ry),(rx,ry),(255,0,0),8,cv2.LINE_AA)
              ratio=int(width/w)
              if w>0 and h>0:
                      print('3channel')
                      y=y+int(height/2)
                      x=x-int(width/12)
                  else:# 머리합성
                      height=height*2
                      width=width*3
                          x=x-w
                          y=y-int(h/2)
                      else:
          break
      cap.release()
        sdetweil @김윤호
        @김윤호 we talked about this in your prior post.
        mm is in JavaScript.
        you can run python from the node helper and get back info to use in mm.
        see the node_helper from
        MMM-FaceReco-DNN
        face-reco-dnn launches a python application/script in the background
        which does all the work talking to openCV to detect faces (or lack thereof)
        the python app then sends a message (thru print to stdout)
        and this message says user logon (name)
        or
        user logoff
        the node_helper captures this message from the python script, and the module then does its solution for logon or logoff
        the module DOES NOT KNOW that python or opencv is involved in creating the message
        from facereco-dnn/node_helper
          // Start face reco script
            self.pyshell = new PythonShell(
              'modules/' + this.name + '/tools/facerecognition.py',
              options
            // check if a message of the python script is comming in
            self.pyshell.on('message', function(message) {
              // A status message has received and will log
              if (message.hasOwnProperty('status')) {
                console.log('[' + self.name + '] ' + message.status);
              // Somebody new are in front of the camera, send it back to the Magic Mirror Module
              if (message.hasOwnProperty('login')) {
                console.log(
                    self.name +
                    'Users ' +
                    message.login.names.join(' - ') +
                    ' logged in.'
                self.sendSocketNotification('user', {
                  action: 'login',
                  users: message.login.names,
              // Somebody left the camera, send it back to the Magic Mirror Module
              if (message.hasOwnProperty('logout')) {
                console.log(
                    self.name +
                    'Users ' +
                    message.logout.names.join(' - ') +
                    ' logged out.'
                  action: 'logout',
                  users: message.logout.names,
        so it is using ‘modules/’ + this.name + ‘/tools/facerecognition.py’,
        I would examine the module /tools/facerecognition.py
        and see what you need to do to replace or interface to that
        • 김 Offline
          김윤호
          @sdetweil said in i want to put my code in modeul:
          can i ask something? first thank you for answer.
          but i don’t need login service. but sdetweil say this is good.
          so i’m going to use this, but i don’t know this very well.
          so what i have to do for working my phython code.
          i try that replace my code in this moduel phython code. but it doesn’t work. i want to what i change this whit rasbbery pi.
          please teach me what i have to change by details. plaese!
            sdetweil @김윤호
            @김윤호 i am sorry, you now know everything I know about opencv, and python in opencv, and the module design.
            i don’t know why it was implemented like this… but I guess this made it simple for MagicMirror… which can only show or hide modules.
            so, on logon you would show and at logoff you would hide
            the module doesn’t need to know any more than that…
            • 김 Offline
              김윤호
              excuse me suddenly my rasberry was had error about login is continued, and it didn’t working. do you know why?
