    MyCommute 'Loading...' assistance please
    3 Posts 3 Posters 857 Views 3 Watching
    • M
      matt216
      Hello,
      Just setting up the MMM-MyCommute module. The config looks ok, but the mirror just displays “Loading…”.
      Using firefox dev tools I can see the following related:
      • 404 on GET http://192.168.0.90:8080/modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
      • Error on loading script: modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
      • The resource from “http://192.168.0.90:8080/modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
      • Uncaught (in promise) TypeError: moment.duration(…).format is not a function
      The API requests do appear to be coming through to the Google Cloud API.
      Any assistance much appreciated. The error messages point to the module code, not my config. I can’t find anything when I grep ‘commute’ or ‘moment’ in the pm2 logs.
        sdetweil @matt216
        @matt216 sounds like you didn’t do the
        npm install
        in the module folder, after the git clone
        M 1 Reply Last reply
        • M
          matt216 @sdetweil
          @sdetweil you are correct, thank you!
