    Just updated Mirror, now mirror will not work.
    14 Posts 2 Posters 3.8k Views 2 Watching
    • N Offline
      Nneuland
      Any help? Why would I be missing files?
      pi@raspberrypi:~ $ cd ~/MagicMirror
      magicmirror@2.16.0 start /home/pi/MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.16.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.16.0 start script.
      npm ERR! /home/pi/.npm/_logs/2021-07-05T23_42_22_591Z-debug.log
        sdetweil @Nneuland
        @nneuland what pi? did u do npm install?
        • N Offline
          Nneuland @sdetweil
          raspberry pi 4.
          I did an install from the magicmirror remote. The last update worked fine, no problems.
          git pull && npm install in the terminal should take care of that, right?
            sdetweil @Nneuland
            @nneuland well, there are others reporting similar problems…
            not sure what the problem is yet
            • N Offline
              Nneuland @sdetweil
              Ohhhh no. Ok. At least I’m not going mad alone. Thank you for letting me know
                sdetweil @Nneuland
                @nneuland but fresh install doesn’t seem to have the problem…
                use my script, it never fails…
                rename the existing MagicMirror folder
                then run the install script.
                see https://github.com/sdetweil/MagicMirror_scripts
                then u can copy your modules over and config.js from the renamed folder
                • N Offline
                  Nneuland @sdetweil
                  Saved again by Sam/. Thank you so very much
                  • N Offline
                    Nneuland @Nneuland
                    @sdetweil I think I celebrated too early.
                    Very odd thing happening. I’ve lost all of my modules. Back to default. What in the world did I do now?
                      sdetweil @Nneuland
                      @nneuland did u copy your stuff over? from the old to the new? including config.js?
                      rename the new modules/default folder out of the way for the copy
                      then from the new modules folder
                      cp -r -p ~/Magicmirror-old/modules .
                      then rm -rf default
                      and rename the saved default folder back
                      • N Offline
                        Nneuland @sdetweil
                        yeah. Just getting a black screen and a cursor.
                          sdetweil @Nneuland
                          @nneuland black screen, look at the messages where u start MagicMirror
                          npm start
                          or pm2
                          if pm2, then the pm2 logs --lines=100
                          will show the same messages
                          • N Offline
                            Nneuland @sdetweil
                            you’re right
                            [09.07.2021 21:41.21.879] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                            Require stack:
                            • /home/pi/MagicMirror/modules/MMM-CoinMarketCap/node_helper.js
                            • /home/pi/MagicMirror/js/app.js
                            • /home/pi/MagicMirror/js/electron.js
                            • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                            not sure why
                              sdetweil @Nneuland
                              @nneuland because request was removed in the latest release, as it has security issue that could not be fixed., and all users recommended to get on to something else ( aka deprecated)
                              in the short term
                              cd ~/MagicMirror
                              npm install request
                              • N Offline
                                Nneuland @sdetweil
                                You’re a gentleman and a scholar!!!
