Just updated Mirror, now mirror will not work.
Any help? Why would I be missing files?
pi@raspberrypi:~/MagicMirror $ npm startmagicmirror@2.16.0 start /home/pi/MagicMirror
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.jssh: 1: ./node_modules/.bin/electron: not found
npm ERR! code ELIFECYCLE
npm ERR! syscall spawn
npm ERR! file sh
npm ERR! errno ENOENT
npm ERR! magicmirror@2.16.0 start:DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
npm ERR! spawn ENOENT
npm ERR!
npm ERR! Failed at the magicmirror@2.16.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2021-07-05T23_42_22_591Z-debug.log -
@nneuland what pi? did u do npm install?
raspberry pi 4.
I did an install from the magicmirror remote. The last update worked fine, no problems.
git pull && npm install in the terminal should take care of that, right?
@nneuland well, there are others reporting similar problems…
not sure what the problem is yet
Ohhhh no. Ok. At least I’m not going mad alone. Thank you for letting me know
@nneuland but fresh install doesn’t seem to have the problem…
use my script, it never fails…
rename the existing MagicMirror folder
then run the install script.see https://github.com/sdetweil/MagicMirror_scripts
then u can copy your modules over and config.js from the renamed folder
Saved again by Sam/. Thank you so very much
@sdetweil I think I celebrated too early.
Very odd thing happening. I’ve lost all of my modules. Back to default. What in the world did I do now?
@nneuland did u copy your stuff over? from the old to the new? including config.js?
rename the new modules/default folder out of the way for the copy
then from the new modules folder
cp -r -p ~/Magicmirror-old/modules .then rm -rf default
and rename the saved default folder back -
yeah. Just getting a black screen and a cursor.
@nneuland black screen, look at the messages where u start MagicMirror
npm start
or pm2if pm2, then the pm2 logs --lines=100
will show the same messages -
you’re right
[09.07.2021 21:41.21.879] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
Require stack:- /home/pi/MagicMirror/modules/MMM-CoinMarketCap/node_helper.js
not sure why
@nneuland because request was removed in the latest release, as it has security issue that could not be fixed., and all users recommended to get on to something else ( aka deprecated)
in the short term
npm install request -
You’re a gentleman and a scholar!!!
