    Raspberry hangs sporadically after turning monitor on/off
    2 Posts 2 Posters 1.6k Views 2 Watching
      SwordMaster
      Hello,
      I build a Magic Mirror with my Raspberry PI. Everything works fine.
      But sometimes (every 1-2 days), the Raspberry hangs after he turned on or off the monitor.
      At first i used this commands:
      sudo vcgencmd display_power 1
      sudo vcgencmd display_power 0
      => Result: Sometimes the Monitor freezed. (even if i killed the magic mirror application via ssh, the monitor was freezed).
      Really really bad was the fact, that i can’t reboot the raspberry via ssh. when i try “sudo reboot”, the raspberry looses the wifi connection, but doesn’t reboot. => not usable any longer.
      Then i tried this commands:
      tvservice --preferred
      tvservice --off
      But here, sometimes, the tvservice hangs after 1-2 days. i can’t control the monitor any longer.
      “tvservice --status” hangs also, and doesn’t get more informations.
      With the tvservice commands i can reboot my system, but reboot every day, is not really cool.
      Does someone have an idea? i already switched the power supply, but nothing changed.
      and i’m sure, that it happens always 2-3 seconds after the monitor turning on or off.
      Kind Regards
      Stefan
      • W
        wizz
        I got the same problem with my mirror so is it an solution?
