    Change Pages with NumPad
    22 Posts 3 Posters 4.9k Views 2 Watching
    • DrKineticPieD Offline
      DrKineticPie @sdetweil
      What do you mean by keystroke?
      I’m really not sure if magicmirror gets the button as a web app I would have to test more closely
        sdetweil @DrKineticPie
        @drkineticpie keystroke, keypress. same thing
        there are tools in steps 1&2 to actually see the key response. before mm gets involved
        DrKineticPieD 1 Reply Last reply Reply Quote 0
          @sdetweil Then I take a closer look at it with the instructions.
          As I said, the Numpad is connected via USB dongle and is recognized but magic mirror apparently does not.
            @drkineticpie also u can enable a bit more logging from the module
            edit the node_helper.js
            and uncomment line 69 ( remove the //), and restart mm
            this.evdevReader.on("EV_KEY", (data) => {
                        // console.log("key : ", data.code, data.value);
            and the module will write a message for each key detected
            the messages will be shown in the terminal window where you do npm start
            DrKineticPieD 2 Replies Last reply Reply Quote 0
              Apparently the keypass does not arrive at the mirror
              However, I have to say that the shortcuts of magicmirror work.
              I.mean F11 and Alt and a Key
                @drkineticpie is there a key definition in the test steps defined in the module instructions?
                do u need to use a special device name to read it?
                also found by using the instructions
                  DrKineticPie
                  Please forgive me my English is really not particularly good :D
                  If I do the steps 1&2 from the tutorial is called my keyboard mini Keyboard
                    @drkineticpie but you should be able to get the key names
                      @sdetweil said in Change Pages with NumPad:
                      pi@Dashboard:~ $ evtest /dev/input/event0
                      Input driver version is 1.0.1
                      Input device ID: bus 0x3 vendor 0x1997 product 0x2433 version 0x111
                      Input device name: "  mini keyboard"
                      Supported events:
                        Event type 0 (EV_SYN)
                        Event type 1 (EV_KEY)
                          Event code 1 (KEY_ESC)
                          Event code 2 (KEY_1)
                          Event code 3 (KEY_2)
                          Event code 4 (KEY_3)
                          Event code 5 (KEY_4)
                          Event code 6 (KEY_5)
                          Event code 7 (KEY_6)
                          Event code 8 (KEY_7)
                          Event code 9 (KEY_8)
                          Event code 10 (KEY_9)
                          Event code 11 (KEY_0)
                          Event code 12 (KEY_MINUS)
                          Event code 13 (KEY_EQUAL)
                          Event code 14 (KEY_BACKSPACE)
                          Event code 15 (KEY_TAB)
                          Event code 16 (KEY_Q)
                          Event code 17 (KEY_W)
                          Event code 18 (KEY_E)
                          Event code 19 (KEY_R)
                          Event code 20 (KEY_T)
                          Event code 21 (KEY_Y)
                          Event code 22 (KEY_U)
                          Event code 23 (KEY_I)
                          Event code 24 (KEY_O)
                          Event code 25 (KEY_P)
                          Event code 26 (KEY_LEFTBRACE)
                          Event code 27 (KEY_RIGHTBRACE)
                          Event code 28 (KEY_ENTER)
                          Event code 29 (KEY_LEFTCTRL)
                          Event code 30 (KEY_A)
                          Event code 31 (KEY_S)
                          Event code 32 (KEY_D)
                          Event code 33 (KEY_F)
                          Event code 34 (KEY_G)
                          Event code 35 (KEY_H)
                          Event code 36 (KEY_J)
                          Event code 37 (KEY_K)
                          Event code 38 (KEY_L)
                          Event code 39 (KEY_SEMICOLON)
                          Event code 40 (KEY_APOSTROPHE)
                          Event code 41 (KEY_GRAVE)
                          Event code 42 (KEY_LEFTSHIFT)
                          Event code 43 (KEY_BACKSLASH)
                          Event code 44 (KEY_Z)
                          Event code 45 (KEY_X)
                          Event code 46 (KEY_C)
                          Event code 47 (KEY_V)
                          Event code 48 (KEY_B)
                          Event code 49 (KEY_N)
                          Event code 50 (KEY_M)
                          Event code 51 (KEY_COMMA)
                          Event code 52 (KEY_DOT)
                          Event code 53 (KEY_SLASH)
                          Event code 54 (KEY_RIGHTSHIFT)
                          Event code 55 (KEY_KPASTERISK)
                          Event code 56 (KEY_LEFTALT)
                          Event code 57 (KEY_SPACE)
                          Event code 58 (KEY_CAPSLOCK)
                          Event code 59 (KEY_F1)
                          Event code 60 (KEY_F2)
                          Event code 61 (KEY_F3)
                          Event code 62 (KEY_F4)
                          Event code 63 (KEY_F5)
                          Event code 64 (KEY_F6)
                          Event code 65 (KEY_F7)
                          Event code 66 (KEY_F8)
                          Event code 67 (KEY_F9)
                          Event code 68 (KEY_F10)
                          Event code 69 (KEY_NUMLOCK)
                          Event code 70 (KEY_SCROLLLOCK)
                          Event code 71 (KEY_KP7)
                          Event code 72 (KEY_KP8)
                          Event code 73 (KEY_KP9)
                          Event code 74 (KEY_KPMINUS)
                          Event code 75 (KEY_KP4)
                          Event code 76 (KEY_KP5)
                          Event code 77 (KEY_KP6)
                          Event code 78 (KEY_KPPLUS)
                          Event code 79 (KEY_KP1)
                          Event code 80 (KEY_KP2)
                          Event code 81 (KEY_KP3)
                          Event code 82 (KEY_KP0)
                          Event code 83 (KEY_KPDOT)
                          Event code 85 (KEY_ZENKAKUHANKAKU)
                          Event code 86 (KEY_102ND)
                          Event code 87 (KEY_F11)
                          Event code 88 (KEY_F12)
                          Event code 89 (KEY_RO)
                          Event code 90 (KEY_KATAKANA)
                          Event code 91 (KEY_HIRAGANA)
                          Event code 92 (KEY_HENKAN)
                          Event code 93 (KEY_KATAKANAHIRAGANA)
                          Event code 94 (KEY_MUHENKAN)
                          Event code 95 (KEY_KPJPCOMMA)
                          Event code 96 (KEY_KPENTER)
                          Event code 97 (KEY_RIGHTCTRL)
                          Event code 98 (KEY_KPSLASH)
                          Event code 99 (KEY_SYSRQ)
                          Event code 100 (KEY_RIGHTALT)
                          Event code 102 (KEY_HOME)
                          Event code 103 (KEY_UP)
                          Event code 104 (KEY_PAGEUP)
                          Event code 105 (KEY_LEFT)
                          Event code 106 (KEY_RIGHT)
                          Event code 107 (KEY_END)
                          Event code 108 (KEY_DOWN)
                          Event code 109 (KEY_PAGEDOWN)
                          Event code 110 (KEY_INSERT)
                          Event code 111 (KEY_DELETE)
                          Event code 113 (KEY_MUTE)
                          Event code 114 (KEY_VOLUMEDOWN)
                          Event code 115 (KEY_VOLUMEUP)
                          Event code 116 (KEY_POWER)
                          Event code 117 (KEY_KPEQUAL)
                          Event code 119 (KEY_PAUSE)
                          Event code 121 (KEY_KPCOMMA)
                          Event code 122 (KEY_HANGUEL)
                          Event code 123 (KEY_HANJA)
                          Event code 124 (KEY_YEN)
                          Event code 125 (KEY_LEFTMETA)
                          Event code 126 (KEY_RIGHTMETA)
                          Event code 127 (KEY_COMPOSE)
                          Event code 128 (KEY_STOP)
                          Event code 129 (KEY_AGAIN)
                          Event code 130 (KEY_PROPS)
                          Event code 131 (KEY_UNDO)
                          Event code 132 (KEY_FRONT)
                          Event code 133 (KEY_COPY)
                          Event code 134 (KEY_OPEN)
                          Event code 135 (KEY_PASTE)
                          Event code 136 (KEY_FIND)
                          Event code 137 (KEY_CUT)
                          Event code 138 (KEY_HELP)
                          Event code 140 (KEY_CALC)
                          Event code 142 (KEY_SLEEP)
                          Event code 150 (KEY_WWW)
                          Event code 152 (KEY_SCREENLOCK)
                          Event code 158 (KEY_BACK)
                          Event code 159 (KEY_FORWARD)
                          Event code 161 (KEY_EJECTCD)
                          Event code 163 (KEY_NEXTSONG)
                          Event code 164 (KEY_PLAYPAUSE)
                          Event code 165 (KEY_PREVIOUSSONG)
                          Event code 166 (KEY_STOPCD)
                          Event code 173 (KEY_REFRESH)
                          Event code 176 (KEY_EDIT)
                          Event code 177 (KEY_SCROLLUP)
                          Event code 178 (KEY_SCROLLDOWN)
                          Event code 179 (KEY_KPLEFTPAREN)
                          Event code 180 (KEY_KPRIGHTPAREN)
                          Event code 183 (KEY_F13)
                          Event code 184 (KEY_F14)
                          Event code 185 (KEY_F15)
                          Event code 186 (KEY_F16)
                          Event code 187 (KEY_F17)
                          Event code 188 (KEY_F18)
                          Event code 189 (KEY_F19)
                          Event code 190 (KEY_F20)
                          Event code 191 (KEY_F21)
                          Event code 192 (KEY_F22)
                          Event code 193 (KEY_F23)
                          Event code 194 (KEY_F24)
                          Event code 240 (KEY_UNKNOWN)
                        @drkineticpie so it should be
                        type 1, code 2, for the numb pad 1 key
                        • 3 / 3
