    Calendar Ext2 positionOrder
    9 Posts 2 Posters 1.9k Views 2 Watching
    • H Offline
      harmZj
      Hey there,
      Working on the calendar and I’m actually getting somewhere… currently I am working on getting a 5 day view of my calendar which I successfully have and then an upcoming for what’s coming up soon.
      What I’m trying to do is get the 5 day daily view to be above my rss feed. So I changed the positionOrder to 0 for daily.
      But then that changes the upcoming so it’s also before the clock on the top_left. What do I need to add to the js file in order to make upcoming on top_left appear below the clock, but keep the 5 day daily view above the rss feed.
      Any tips?
        MMRIZE @harmZj
        @harmzj
        Current in top_left region
        clock (0)
        RSS (1)
        What you want
        clock (0)
        Your CALEXTVIEW (1)
        Rss (2)
        Set position order to 1. It will place the view in the second position.
        It is zero-based, so if you set 0, it means the first position(clock)
        • H Offline
          harmZj @MMRIZE
          @mmrize ok that makes sense. But then I guess which file do I edit to achieve this? B/c I was editing the CalendarExt2.js
          Only view I could change seemed to be daily. Which would change both upcoming, and daily…
          So in top_left bar it would be upcoming 1st and then clock next. Which I want it clock 1st and then upcoming calendar events next.
          Then my bottom_bar would be correct by changing positionOrder to 0 by placing the 5 day daily view 1st above the RSS feed.
          The issue is I just couldn’t achieve the position I wanted on both upcoming and daily.
            MMRIZE @harmZj
            @harmzj NO!
            Users SHOULD NOT modify source at any reason. You HAVE TO adjust your config file.
            See the example; https://forum.magicmirror.builders/topic/15614/mmm-calendarext2-example-request/2
            • H Offline
              harmZj @MMRIZE
              @mmrize ok so I’ll revert to where it says positionOrder -1, but then you’re saying I set positionOrder where ? In the config.js file?
                MMRIZE @harmZj
                @harmzj
                I am going on driving in a minute. So cannot reply detailly. If you don’t mind I’ll show you the example in 1-2 hours. Anyway, it will be better to show your current config.js MMM-CalendarExt2 parts here.
                • H Offline
                  harmZj @MMRIZE
                  @mmrize sure thing. I will post in a few hours. Thanks :)
                    MMRIZE @harmZj
                    @harmzj
                    I believe this is similar to what you want.
                      module: "MMM-CalendarExt2",
                            url: "https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics",
                            icon: "emojione:chicken"
                            url: "https://www.google.com/calendar/ical/h2suh4c1iqvktk4olmfqtth4lg%40group.calendar.google.com/public/basic.ics",
                            icon: "emojione-v1:shield"
                        views: [
                            calendars: ["Tottenham", "Leeds"],
                            mode: "upcoming",
                            slotMaxHeight: "150px",
                            positionOrder: 1
                            mode: "daily",
                            type: "row",
                            positionOrder: 0,
                            slotCount: 5,
                            slotMaxHeight: "100px",
                            slotSubTitleFormat: "MMM do",
                            position: "bottom_bar"
                        scenes: [
                            views: ["UPCOMING_GAME", "DAILY_GAME"],
                    • H Offline
                      harmZj @MMRIZE
                      @mmrize you’re exactly right. I will plug in the position order like you have and see what I get. Thanks :)… I was up till 2AM very irritated I couldn’t get it right lol.
