    MM standard Newsfeed
    3 Posts 2 Posters 855 Views 2 Watching
    • AssassinsA Offline
      Assassins
      I get this error today, but i dont now why i get it, someone there can help. ???
      the url work fine.
      [01.10.2021 13:33.29.814] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.bt.dk/bt/seneste/rss FetchError: request to https://www.bt.dk/bt/seneste/rss failed, reason: certificate has expired
          at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1461:11)
          at ClientRequest.emit (events.js:315:20)
          at TLSSocket.socketErrorListener (_http_client.js:426:9)
          at TLSSocket.emit (events.js:315:20)
          at emitErrorNT (internal/streams/destroy.js:92:8)
          at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
          at processTicksAndRejections (internal/process/task_queues.js:84:21) {
        type: 'system',
        errno: 'CERT_HAS_EXPIRED',
        code: 'CERT_HAS_EXPIRED'
      The config.js code
            module: 'newsfeed',
            position: 'bottom_bar',
              feeds: [
                  title: 'BT',
                  url: 'https://www.bt.dk/bt/seneste/rss'
              showSourceTitle: true,
              showPublishDate: true,
              broadcastNewsFeeds: true,
              broadcastNewsUpdates: true
        M_M
        Welcome to the club!
        I have the same error.
        First I thought this is about the Lets Encrypt Certificate, but all of the newsfeeds I use doesn’t use Lets Encrypt.
        The certificate is ok when you use curl…
        Marcus
        AssassinsA 1 Reply Last reply Reply Quote 0
          Assassins @M_M
          @m_m
          Look here, and write : https://github.com/MichMich/MagicMirror/issues/2671
