    Error: valid-url not found MMM-CalendarExt(2)
    2 Posts 2 Posters 758 Views 2 Watching
    • J
      jamesarm
      Updated node to latest on rpi 4 and magic mirror to latest to try and fix GoogleTTS and now I am getting an error on both the CalendarExt and Ext2 modules. I removed and reinstalled them and same issue.
      0|mm | [03.10.2021 18:36.30.918] [ERROR] App threw an error during load
      0|mm | [03.10.2021 18:36.30.922] [ERROR]
      0|mm | Error: Cannot find module ‘valid-url’
      0|mm | Require stack:
      0|mm | - /home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js
      0|mm | - /home/pi/MagicMirror/js/app.js
      0|mm | - /home/pi/MagicMirror/js/electron.js
      0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|mm | -
      0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
      0|mm | at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
      0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|mm | at Module._load (internal/modules/cjs/loader.js:732:27)
      0|mm | at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
      0|mm | at Module.require (internal/modules/cjs/loader.js:959:19)
      0|mm | at require (internal/modules/cjs/helpers.js:88:18)
      0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
      0|mm | at Module._compile (internal/modules/cjs/loader.js:1078:30)
      0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
      0|mm | [03.10.2021 18:36.30.923] [ERROR] Whoops! There was an uncaught exception…
      0|mm | [03.10.2021 18:36.30.932] [ERROR]
      0|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      0|mm | - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
        sdetweil @jamesarm
        @jamesarm in the module folder do
        npm install valid-url --save
