    MMM-Parcel
    4 Posts 3 Posters 1.4k Views 3 Watching
    • J
      JohnBachini
      Any ideas on this ? is this to do with the unused (undocumented) modules being removed.
      [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: Must use import to load ES Module: /home/pi/MagicMirror/modules/MMM-Parcel/node_modules/node-fetch/src/index.js
      require() of ES modules is not supported.
      require() of /home/pi/MagicMirror/modules/MMM-Parcel/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/MMM-Parcel/node_helper.js is an ES module file as it is a .js file whose nearest parent package.json contains "type": "module" which defines all .js files in that package scope as ES modules.
      Instead rename index.js to end in .cjs, change the requiring code to use import(), or remove "type": "module" from /home/pi/MagicMirror/modules/MMM-Parcel/node_modules/node-fetch/package.json.
      M 1 Reply Last reply
      • M
        MMRIZE @JohnBachini
        @johnbachini
        The Mmm-Parcel may be using node-fetch, but it calls that in wrong way. Ask the creator.
        karsten13K 1 Reply Last reply
        • karsten13K
          karsten13 @MMRIZE
          https://github.com/martinkooij/MMM-Parcel/pull/31
          J 1 Reply Last reply
          • J
            JohnBachini @karsten13
            @karsten13 Great, fixed it, cheers
