    MMM-Fuel - multi instances
    2 Posts 2 Posters 609 Views 2 Watching
    • L Offline
      Liz
      Cause we live close to the border with largely varying fuel prices (switzerland, austria, germany) I wanted to set up 3 instances of the MMM-Fuel module to compare prices.
      It appears to only use one (the first) of the configured providers and locations.
      The module is shown twice on my mirror, with the same stations. It rotates through both fuel types and distance sorting then starts at the first fuel type again.
      If I only use one of my configurations either one works as intended.
      Is there any way to start multipe instances?
      this is my config for two locations:
      		module: "MMM-Fuel",
      			provider: "tankerkoenig",
      			api_key: "myAPiKey for tankerkönig",
      			lat: 47.791416,
      			lng: 9.882849,
      			radius: 15,
      			types: ["diesel", "e5"],
      			// all your config options, which are different than their default values
      		module: "MMM-Fuel",
      			provider: "spritpreisrechner",
      			lat: 47.2722109,
      			lng: 9.6025761,
      			radius: 5,
        sdetweil @Liz
        @liz looking at the code, this module doesn’t support multiple instances.
        you might be able to make a setup for this
        copy the MMM-Fuel folder to
        new folder MMM-Fuel1
        inside MMM-Fuel1, rename everything MMM-Fuel to MMM-Fuel1
        inside templates, rename MMM-Fuel.njk to MMM-Fuel1.njk
        inside the MMM-Fuel1.js, change places of MMM-Fuel to MMM-Fuel1
        Module.register('MMM-Fuel', {   // <-
            getStyles() {
                return ['font-awesome.css', 'MMM-Fuel.css']; .// <-
            getTemplate() {
                return 'templates/MMM-Fuel.njk';  // <-
        in your multi-instance config.js, change one of them to module:“MMM-Fuel1”
