    How to Hide Modules After Start (using setTimeout)
    8 Posts 3 Posters 1.5k Views 3 Watching
    • T
      tonkxy
      Hello!
      I am using the MMM-ModuleBar. It creates a menu of my modules and makes buttons I was trying to set up after the menu is built, it will hide the modules automatically instead of wating for an onclick scenario. I am unsure where to put the function… Here is what I am looking at so far, I have it trying to hide modules after the menu is built. Should I build a for loop like in the getDom? Thank you for your help!
      // Override dom generator.
      	getDom: function() {
      		var overlay = document.createElement("div");
      		var menu = document.createElement("span");
      		menu.className = "menubar-menu";
      		menu.id = this.identifier + "_menu";
      		menu.style.flexDirection = this.config.direction;
      		// Sends each button to the "createButton" function be created.
      		for (var num in this.config.buttons) {
      			menu.appendChild(this.createButton(this, num, this.config.buttons[num],
      			this.config.picturePlacement, overlay));
      		menu.appendChild(overlay);
      		return menu;
      setTimeout(function(){
      menu.hide({self.config.animationSpeed, {force: self.config.allowForce});
      //modules[i].hide(self.config.animationSpeed, {force: self.config.allowForce});
      // Sets the defined symbol for hidden module.
      //if (typeof data.symbol2 !== 'undefined') {
      //symbol.className = faclassName + data.symbol2;
      	// Set the size if it's set.
      //	if (data.size) {
      //	symbol.className += " fa-" + data.size;
      //	symbol.className += data.size == 1 ? "g" : "x";
      // Sets the defined image for hidden module.
      //	} else if (typeof data.img2 !== 'undefined') {
      //	image.className = "menubar-picture";
      //	image.src = data.img2;
      	// Prints in the console what just happened (adding the ID).
      //	console.log("Hiding "+modules[i].name+" ID: "+idnr[1]);
      }, 15000);
      	// Creates the buttons.
      	createButton: function (self, num, data, placement, overlay) {
      		var hidden = true;
      		// Creates the span element to contain all the buttons.
      		var item = document.createElement("span");
      		// Builds a unique identity / button.
      		item.id = self.identifier + "_button_" + num;
      		// Sets a class to all buttons.
      		item.className = "menubar-button";
      		//takes awesome font icon name
      		var faclassName = "menubar-picture ";
      		// Makes sure the width and height is at least the defined minimum.
      		item.style.minWidth = self.config.minWidth;
      		item.style.minHeight = self.config.minHeight;
      		// Collects all modules loaded in MagicMirror.
      		var modules = MM.getModules();
      		// When a button is clicked, the module either gets hidden or shown depending on current module status.
      		item.addEventListener("click", function () {
      				// Lists through all modules for testing.
      				for (var i = 0; i < modules.length; i++) {
      				// Check if the current module is the one.
      				if (modules[i].name === data.module) {
      					// Splits out the module number of the module with the same name.
      					var idnr = modules[i].data.identifier.split("_");
      					// Check if the idnum is an array or not
      					if (Array.isArray(data.idnum)) {
      						// If it's an array, check what numbers are in it.
      						var idnumber = data.idnum.find(function(element) {
      							// Number of the module is found in the array.
      							return element == idnr[1];
      					// If idnum is not an array.
      					} else {
      						// Set the module id to hide.
      						var idnumber = data.idnum;
      					// Checks if idnum is set in config.js. If it is, it only hides that modules with those numbers and name, if not hides all modules with the same name.
      					if (idnr[1] == idnumber || data.idnum == null) {
      						// Check if the module is hidden.
      						if (modules[i].hidden) {
      							// Shows the module.
      							modules[i].show(self.config.animationSpeed, {force: self.config.allowForce});
      							// Sets the defined symbol for shown module.
      							if (typeof data.symbol !== 'undefined') {
      								symbol.className = faclassName + data.symbol;
      								if (data.size) {
      							// Sets the defined image for shown module.
      							} else if (typeof data.img !== 'undefined') {
      								image.src = data.img;
      							console.log("Showing "+modules[i].name+" ID: "+idnr[1]);
      						} else {
      							// Hides the module.
      								if (data.size) {
        sdetweil @tonkxy
        @tonkxy I don’t understand your question
        should you loop like in getDom.?
        the click event handler will tell you which button object was clicked.
        the pointer
        this
        will be pointing at the button object
        u can query attributes u set at create time
        u can set arbitrary attributes to hold info.
        number, name, …
        • T
          tonkxy @sdetweil
          @sdetweil I am wanting the mirror to start, and once it starts and after it builds the menu it will auto hide the modules instead of me having to click through the buttons. I am just trying to autohide them once without clicking the button. Then have the option to toggle on and off. I hope that makes more sense
            sdetweil @tonkxy
            @tonkxy if u mean where to enable the timer
            u should wait to all the modules are loaded
            that is a notification_received event
            then do your setTimeout there
            and the when the timer expires do the loop thru all the modules to hide.
            • T
              tonkxy @sdetweil
              @sdetweil I’ve tried a few things and just am struggling with this notification received. Any advice with what I have so far?
              /grabs information needed for refresh
              notificationReceived: function (notification, payload, sender) {
              	  if (notification === 'MODULE_DOM_CREATED') {
              					} else {
              								if (data.size) {
                sdetweil @tonkxy
                @tonkxy see the doc, that’s the wrong notification
                https://docs.magicmirror.builders/development/core-module-file.html#notificationreceived-notification-payload-sender
                hamptonlindsayH 1 Reply Last reply Reply Quote 0
                • hamptonlindsayH
                  hamptonlindsay @sdetweil
                  @sdetweil I can’t open this link :(
                    sdetweil @hamptonlindsay
                    @hamptonlindsay go to the MagicMirror GitHub page, click the documentation link, then the three bar menu top left, pick module development
