    • Search
    Make a module or region stay on top
    Custom CSS
    • C
      charliehoward last edited by
      Is there a way to make a certain module or region be on top of other modules if there’s overlap? Specifically want my clock to overlay another module but by default it’s putting the clock under it.
        sdetweil @charliehoward last edited by
        @charliehoward you could try in custom.css
        .modulename {
           z-index: 1;
        and increase the number if need be. that will move the module content closer to you as the user,
        negative number is farther away
        • C
          charliehoward @sdetweil last edited by
          @sdetweil I’ve tried that both the .region and the .modulenames but it isn’t working
            @charliehoward only thing I can suggest is to use the developers window and change the settings there til it works then save that to custom.css…
            • F
              Fabaude last edited by
              Hello,
              maybe a mistake that I will write but have you tried to place the module (top) before the other module (bottom) in Config.js?
              The 2 being on the same “position”!
