    Module resulting black screen "electron"
    3 Posts 2 Posters 1.0k Views 2 Watching
      sultan.y
      New to Magic Mirror
      have been trying to install the MMM Prayer Times module, but eery time all i see is a black screen “electron”
      i start magic mirror using npm run start
      when i comment out the module, everything works fine, not sure what im doing wrong, this is the error i get
      pi@raspberrypi:~ $ cd MagicMirror/
      pi@raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.17.1 start /home/pi/MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [21.12.2021 16:14.55.709] [LOG] Starting MagicMirror: v2.17.1
      [21.12.2021 16:14.55.720] [LOG] Loading config …
      [21.12.2021 16:14.55.726] [LOG] Loading module helpers …
      [21.12.2021 16:14.55.734] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-MyPrayerTimes/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      [21.12.2021 16:14.55.735] [LOG] Loading module helpers …
      [21.12.2021 16:14.55.738] [ERROR] App threw an error during load
      [21.12.2021 16:14.55.741] [ERROR] Error: Cannot find module ‘request’
      Require stack:
      • at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
        at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (internal/modules/cjs/loader.js:732:27)
        at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
        at Module.require (internal/modules/cjs/loader.js:959:19)
        at require (internal/modules/cjs/helpers.js:88:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-MyPrayerTimes/node_helper.js:10:17)
        at Module._compile (internal/modules/cjs/loader.js:1078:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
        [21.12.2021 16:14.55.743] [ERROR] Whoops! There was an uncaught exception…
        [21.12.2021 16:14.55.751] [ERROR] Error: Cannot find module ‘request’
        Require stack:
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/modules/MMM-MyPrayerTimes/node_helper.js’,
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/js/electron.js’,
        ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [21.12.2021 16:14.55.755] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [21.12.2021 16:14.55.756] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [21.12.2021 16:14.56.003] [LOG] Launching application.
        ^C[21.12.2021 16:15.51.413] [LOG] Shutting down server…
        [21.12.2021 16:15.51.418] [ERROR] Whoops! There was an uncaught exception…
        [21.12.2021 16:15.51.423] [ERROR] TypeError: Cannot read property ‘close’ of undefined
        at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
        at App. (/home/pi/MagicMirror/js/electron.js:139:7)
        at App.emit (events.js:315:20)
        [21.12.2021 16:15.51.426] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [21.12.2021 16:15.51.427] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @sultan.y
        @sultan-y see
          sultan.y @sdetweil
          excellent! Solved!!
          In recent mm releases we have removed libraries that are discontinued ( aka deprecated).
          many mm modules used these but didn’t document it. so they fail
          to fix this you need to install the library in the module folder
          if the module does NOT provide a file called package.json, then do
          npm init -y
          then regardless do
          npm install request
