    [MMM-WeatherChart] How to remove the right hand side space?
    7 Posts 2 Posters 1.6k Views 2 Watching
    • C Offline
      codac
      Hi, I would like to remove the space on the right hand side (red marked) so that the module sticks to the mirrors border, the same way the weather module does.
      I’ve tried a lot with custom.css already but I can’t manage to finally remove it.
      • C Offline
        codac @sdetweil
        @sdetweil This is what worked for me:
        .MMM-WeatherChart canvas[style] {
        	position: absolute;
                right: -35px;
          sdetweil @codac
          @codac looks like the code places it to the left edge
          	img.style.left = "0px";
          so your custom.css would need to change that
          .MMM-WeatherChart img {
                 left: 40px;
          you will have to use the dev console to figure out what the left setting should be.
          see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1640538468966
          ps, you don’t remove the space, you shift the image to the right edge
          • C Offline
            codac @sdetweil
            @sdetweil thank you for the reply.
            I used the Developer-Console but I did not see the img.style.left.
            The CSS code provided does
            not change the behaviour unfortunately.
              sdetweil @codac
              @codac said in [MMM-WeatherChart] How to remove the right hand side space?:
              you have to select elements tab, click the pointer (top left) and then click on the image (the chart)
              and then the styles for the chart image(img html tag) will be in the right column of the dev console…
              the middle column will be the html, so the img tag should be selected
              • C Offline
                codac @sdetweil
                @sdetweil There is no image/img Tag at all.
                I have a class module-content that covers the whole
                module. In that div there is a canvas, that canvas is more narrow in a sence that the red marked area is missing.
                  sdetweil @codac
                  @codac interesting. which module are you using? github link…
                  one I pulled up was showing a fixed image… not drawing one…
                  (I have a module that draws a chart…so I will look too )
                  • C Offline
                    codac @sdetweil
                    	position: absolute;
                            right: -35px;
