    Live-sync mm calendar <- nextcloud calendar
    7 Posts 3 Posters 1.9k Views 3 Watching
      droidus
      Is there any way to show events from my Nextcloud Calendar to my MM instance dashboard?
        sdetweil @droidus
        @droidus supposedly you need to use this type of cal entry definition in MM cal config
        symbol: "calendar",
        url: "https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/personal/?export",
        user: "USER",
        pass: "PASSW",
        method: "basic",
          droidus @sdetweil
          @sdetweil I added this code, but it is not showing up on my dashboard. I did a pm2 restart mm.
            sdetweil @droidus
            @droidus and u changed the URL to have MYDOMAIN and USER specify whatever nextcloud uses for you?
              bdream
              @droidus I use the link provided from NC in
              https://nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USERS/pers%c3%b6nlich/
              adding ?export
              Username and password I need to add to the url as shown here:
              url: "https://USER:PASSWORD@nextcloud.MYDOMAIN.xyz/remote.php/dav/calendars/USER/pers%c3%b6nlich?export"
              cheers, bdream
                droidus @sdetweil
                @sdetweil said in Live-sync mm calendar <- nextcloud calendar:
                Yes.
                @bdream said in Live-sync mm calendar <- nextcloud calendar:
                adding ?export
                This tells me file not found.
                  bdream
                  What is, if you take the link given by NC adding ?export at the end and USER:PASSWORD as shown and put it into your web browser.
                  Make sure to change USER and PASSWORD with your credentials.
                  This should open/download the ics-file
                  cheers, bdream
