    dpkg: error unpacking nodejs during MM2 manual installation
    manual installationerror unpacking nodejs
    4 Posts 2 Posters 1.2k Views 2 Watching
    • J
      jackl6681
      During installation of MM2 and I am getting an error when trying to unpack nodejs in the first step of the manual installation…
      curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
      sudo apt install -y nodejs
      The error is:
      Preparing to unpack …/nodejs_16.13.2-deb-1nodesource1_armhf.deb …
      Unpacking nodejs (16.13.2-deb-1nodesource1) over (12.22.5~dfsg-2~11u1) …
      dpkg: error processing archive /var/cache/apt/archives/nodejs_16.13.2-deb-1nodesource1_armhf.deb (–unpack)
      trying to overwrite ‘/usr/share/doc/nodejs/api/fs.html’, which is also in package nodejs-doc 12.22.5~dfsg-
      2~11u1
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      I have started from scratch and reloaded RP OS 3X and get the same error at the same point each time.
      Using a Raspberry Pi 4 with 4 GB and a 64 GB microSD card.
      RP functions perfectly just cannot get past this error.
      Thanks advance for any assistance.
        sdetweil @jackl6681
        @jackl6681 yes, bullseye is a mess…
        In my install script I use n to install the right version
        sudo npm install n -g
        then to install node 16(latest)
        n 16
        you can install a specific version
        n 16.1.0
        n is the nodejs version of nvm ( node version manager)
        I was unsuccessful at recovering the system after trying to install without n. and had to reflash.
        see
        n --help gives you more info
        you can switch between versions
        you can run one version for one app, and a different version for another app.
        all kinds of cool uses
        n does not work on windows
        • J
          jackl6681 @sdetweil
          @sdetweil - ran your script with new flash , kicked out line 375
          pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
          $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
          $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
          $$$$$$ $$ | _
          $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
          $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
          $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
          _
          | _
          | _
          | _
          $$ |_| _
          |_| _|_|_| __| _
          / _| _______|
          _
          ____/
          install log being saved to /home/pi/install.log
          Installing helper tools …
          E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 1376 (packagekitd)
          E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
          Updating packages …
          bash: line 144: pv: command not found
          Check current Node installation …
          Node.js is not installed.
          Installing Node.js …
          N: Be aware that removing the lock file is not a solution and may break your system.
          bash: line 262: node: command not found
          Node.js installation Done! version=
          Check current NPM installation …
          npm is not installed.
          Installing npm …
          sudo: npm: command not found
          bash: line 310: npm: command not found
          npm installation Done! version=V
          Cloning MagicMirror …
          Cloning into ‘MagicMirror’…
          remote: Enumerating objects: 330, done.
          remote: Counting objects: 100% (330/330), done.
          remote: Compressing objects: 100% (289/289), done.
          remote: Total 330 (delta 51), reused 148 (delta 29), pack-reused 0
          Receiving objects: 100% (330/330), 448.62 KiB | 172.00 KiB/s, done.
          Resolving deltas: 100% (51/51), done.
          Cloning MagicMirror Done!
          Installing dependencies …
          bash: line 375: npm: command not found
          • J
            jackl6681
            Thanks much! sdetweil…
            was able to get MM2 up and running.
            Cheers from Toronto Ontario Canada
