    Calendar Color
    27 Posts 12 Posters 19.3k Views 13 Watching
      sdetweil @RJDaPirate
      @RJDaPirate the code does this
      if (this.config.colored && !this.config.coloredSymbolOnly) {
      				eventWrapper.style.cssText = "color:" + this.colorForUrl(event.url);
      	colorForUrl: function (url) {
      		return this.getCalendarProperty(url, "color", "#fff");
        RJDaPirate @sdetweil
        @sdetweil This is not visible in the config.js file. Earlier in the thread you instructed another user not the change settings in source instead of the config.js. Where are the setting you highlighted?
          @RJDaPirate i am just showing the code that uses the settings from config.js… not changing it…
          this.config.colored
          u have colored: true, in config.js calendar config section
          then it looks up color value by url…
          if not found it return #fff as the color…
          u have 6 digit color values…
            @sdetweil Understand you did not “edit”. Do not understand what I have done wrong? Cannot find examples of Calendar Module Config.js with seperate colors for different url (google) calendars. Is there a knowledge document you’d recommend I read thru that covers those config: { colored:…
              @RJDaPirate I wasn’t aware of color support myself til you mentioned it.
              the online doc is all I am aware of
                RJDaPirate
                @sdetweil , The lack of a “proper” symbol was my undoing.
                • P Offline
                  pastormingle
                  how do you change the schedule time color and font? Mine seems to be gray even after sending the fade to false.
                  • 3 / 3
