    Nunjuncks on iOS 9 (iPad3)
    8 Posts 2 Posters 777 Views 1 Watching
    • ? Offline
      [[global:former-user]]
      This post is deleted!
        sdetweil @Guest
        @hango no idea.
        arrow functions also not supported
        more of base code converted to es6 idioms which aren’t supported on iOS 9.
        • ? Offline
          [[global:former-user]] @sdetweil
            sdetweil @Guest
            @hango you will have to load the scripts in the index.html, before any app function code gets loaded
            https://github.com/es-shims/es5-shim
            • ? Offline
                sdetweil @Guest
                @hango
                Function.prototype.bind
                warning Caveat: the bound function has a prototype property. <=====
                https://stackoverflow.com/questions/35763391/javascript-adding-property-to-function
                  maybe you wanted es6 shim
                  https://github.com/paulmillr/es6-shim
                  https://www.npmjs.com/package/es6-shim
                  • ? Offline
