MMM-NotificationTrigger second trigger not working
14 Posts 3 Posters 3.4k Views 3 Watching
    Arynio @sdetweil
    @sdetweil Yes the TURN_OFF gets emitted and i can see it. But MMM-NotificationTrigger doesn’t react to it, doesn’t fire the OKAY and doesnt execute the “echo ‘standby 0.0.0.0’ | cec-client -s -d 1”
      MMRIZE @Arynio
      @arynio
      I haven’t tested. But as far as I know, a notification from the module itself would not be heard by itself to prevent infinite loop possibility.
        MMRIZE @Arynio
        @arynio
        https://github.com/MichMich/MagicMirror/blob/26a76f80d63e5c9746b6db712d6901219f8b6b93/js/main.js#L97-L99
        if (module !== sender && (!sendTo || module === sendTo)) {
          module.notificationReceived(notification, payload, sender);
        module.notifcationReceived() doesn’t work when the recipient module and the sending module are the same.
        A module cannot hear its voice.
        If you want to use a chained shell commands with delay, make .sh file and execute it.
        A 1 Reply Last reply Feb 6, 2022, 8:37 PM Reply Quote 1
          Arynio @MMRIZE
          @mmrize Okay will do that thanks
          2 / 2
