    Alexyak/motiondetector... how to?
    9 Posts 2 Posters 4.0k Views 2 Watching
    • C
      Centurion
      https://github.com/alexyak/motiondetector
      First let me start by saying that I know nothing about coding… I’m barely IT literate, so go n00b with the answers please! :)
      I’ve managed to get MagicMirror installed and running on the rPi, I have the rPi camera which I would like to use as to detect when someone is in front of the mirror and come on for a minute or so.
      The module linked above didn’t come with any documentation that I could find, so other than downloading the files into my MM modules directory on the rPi and adding this to my MM config file:
      		module: "motiondetector"
      I don’t know what to do. The screen just stays on indefinitely. Are there some settings I’m missing?
      Also, I did verify that the camera is plugged in and working, the rPi had no trouble using it to take a picture.
      I’ve been trying to find mm log files or something so that I could even see if the motiondetector module was working, but I don’t know where to look or how to access those either.
      Thanks for any pointers or troubleshooting steps!
      • C
        Centurion
        Anyone have any advice???
        Is there some way to check system logs or something?
          Sultan91
          This post is deleted!
            Sultan91
            Hello! I guess waht module is doing it tells to other modules (via sensocketnotification method) kind of “hey I detected motion”. But first of all, after launching npm start keep looking at the console and check for module errors.
            • C
              Centurion @Sultan91
              @Sultan91
              Ok, so what is npm and what’s the console? Sorry!
              • C
                Centurion
                I’ve been reading lots of other modules and they all have instructions that say to use the " npm install" command… Do I need to do that for this mod?
                I’m sorry but there were NO instructions with this mod, and I’m NOT a technical person.
                  Sultan91 @Centurion
                  @Centurion I haven’t used that module though. But for what purposes do you wanna use motion sensor - just to trigger screen on/off in case human body detected? If so check out PIR-motion sensor from 3rd party modules on github.
                  I guess these module is still under development.
                  P.S: In RPi terminal - is your console (you opening Terminal (black window) and in order to launch MagicMirror software you type into Terminal - “npm start”)
                  • C
                    Centurion @Sultan91
                    @Sultan91 Thanks, I ordered those parts on Amazon too since I haven’t gotten much response here.
                    Really hope that one’s easier to figure out.
                    I launch MM by typing “pm2 start mm”. How do people watch the console after they launch it? Someone said to check the logs…?
                      Sultan91 @Centurion
                      @Centurion To watch cromium console hit crt+shift+I, to check Terminal just push alt+Tab
