    MMM-GoogleBirthdaysProvider
    4 Posts 2 Posters 996 Views 2 Watching
    • M
      meralith
      Hi everybody,
      I installed MMM-GoogleBirthdaysProvider, it worked fine for about one week. Now Birthdays aren’t appearing anymore.
      I think it has to do with this:
      “Birthdays are only fetched once, when the node_helper is initialized. Should do that regularly”
      What does it mean? What should I do to initialize it?
      Thank you for your help,
      meralith
        sdetweil @meralith
        @meralith only mm restart causes the nod_helper to start again.
        M 1 Reply Last reply
        • M
          meralith @sdetweil
          @sdetweil I restarted mm several times in the meantime. Seems to have no effect.
          • M
            meralith @meralith
            I had to generate a new token.
            Problem is solved :-)
