    Can I round Precipitation Units
    5 Posts 4 Posters 1.2k Views 5 Watching
      amarko87
      Hey all,
      Just curious if I’m able to round the showPrecipitationAmount units like I can with Temp units. I feel like there’s a way, but without a specific line in the documentation I didn’t want to start poking around since I know so little about coding in general. I’m a woodworker so this is all pretty new to me.
      • kayakbabeK Offline
        kayakbabe
        I figured it out. I wanted to round it off too. No decimal places.
        You have to edit the template files. look for the showPrecipitationAmount if statement. I altered the output a little bit… see below for what I did.
        in forecast.njk
                        {% if config.showPrecipitationAmount %}
                            {% if f.precipitationUnits %}
                                <td class="align-right bright precipitation">
                                    {{ f.precipitation }}{{ f.precipitationUnits }}
                                </td>
        		                {% else %}
                                {% if f.pop %}
                                    <td class="align-right precipitation">
                                        {{(f.pop * 100).toFixed(0)}}%
                                    </td>
                                {% endif %}
                                    {{ f.precipitation | unit("precip") }}
                                </td>
                            {% endif %}
                        {% endif %}
        I found info on the templates by googling nunchucks templates.
          sdetweil @amarko87
          @amarko87 what module are you talking about ?
            amarko87 @sdetweil
            @sdetweil I probably should’ve mentioned that in the post. Just the default Weather module.
            crazylegsC 1 Reply Last reply Reply Quote 0
            • crazylegsC Offline
              crazylegs @amarko87
              @amarko87 There’s currently no option to round precipitation amount in the default Weather module, although I think this should be possible. I’m just curious:
              • Which weather provider are you using?
              • Are you looking for rounding in the ‘forecast’ and/or ‘hourly’ feature of the Weather module?
                kayakbabe
                in forecast.njk
                                        </td>
                		                {% else %}
                                        {% if f.pop %}
                                            </td>
                                        {% endif %}
                                        </td>
                                    {% endif %}
                                {% endif %}
