    Default Calendar lists events one day early
    4 Posts 3 Posters 1.4k Views 3 Watching
      asward2
      I have a public google calendar using the iCal url. This has been working for probably 3 years at this point, no issues. I’ve recently noticed (wife says it’s been a long time, but she didn’t say anything :man_shrugging: ) that ‘all day’ calendar events shown on MM are shown as starting one day early - for example a birthday that is on the 23rd is shown on MM as the 22nd. However, an event with a fixed duration is listed on the correct date.
      I’m in the pacific time zone. The Pi is configured correctly. MM is running in a container, which shares the time config.
      This seems to have occurred with at least one other user. I would have responded to his thread but it’s coming up on it’s second birthday with no responses :-)
      https://forum.magicmirror.builders/topic/13230/calendar-2hours-for-all-day-event?_=1648003429696
        asward2 @sdetweil
        @sdetweil Thanks for the quick reply!
        I had previously verified that all ‘levels’ of the mm are using the correct date and time, and display their timezone properly. The pi, the container, and the display pi were all set to PDT and the time/date was correct. I verified this with the ‘date’ command at a bash terminal.
        The container was syncing to the rpi hosts time by mapping the localtime as a volume.
        version: '3'
        services:
          magicmirror:
            container_name: magicmirror
            image: mm2022:latest
            restart: always
            volumes:
              - /etc/localtime:/etc/localtime:ro
              - ./magic_mirror/config:/opt/magic_mirror/config
              - ./magic_mirror/modules:/opt/magic_mirror/modules
            ports:
              - 8888:8080
        From your comment I decided to set the TZ environment variable in my container as well.
        services:
          magicmirror:
            environment:
                TZ: America/Los_Angeles
            restart: always
            volumes:
            ports:
              - 8888:8080
        This fixed my issue, and all day events now appear on the correct date.
        Thanks again!
        S 1 Reply Last reply Reply Quote 2
          sdetweil @asward2
          @asward2 what MM version are you running?
          cd MagicMirror
          grep version package.json
          show me one of the events from the ICS file
          to get the ics file do
          curl -sL ical_url >somefile.txt
          edit somefile.txt
          locate the vevent
          BEGIN:VEVENT
          END:VEVENT
          u can change any of the text that shows personal info, please don’t edit the dates
          u can direct message me here or you can send an email
          to my same userid on gmail
          I worked a while back with another user that had a similar problem (he was in Hawaii)…
          turns out his system timezone was set to east coast… oops…
            asward2 @sdetweil
            version: '3'
            services:
              magicmirror:
                restart: always
                volumes:
                ports:
                  - 8888:8080
            services:
              magicmirror:
                environment:
                restart: always
                volumes:
                ports:
                  - 8888:8080
            Thanks again!
              sdetweil @asward2
              @asward2 awesome
