    midori cant connect to localhost
    11 Posts 6 Posters 12.7k Views 7 Watching
    • O
      ottobot
      Got magicmirror to start on a pi zero following instrustions that I found on this forum. Now when midori starts I’m getting a connection refused on localhost:8080. I can ping localhost fine from terminal and I’ve added /120 in my whitelist.
      • D
        d-sanchez
        Did you figure out this error? I’m having the same problem
        • O
          ottobot
          Honestly, I didn’t. I spent a few days off and on trying to get things going, finally I reached out to someone on the forum that had a working image and used that. I have a few more zero’s floating around though and I’m planning on trying again from scratch this weekend.
          • B
            bbdv
            Hi Guy’s, I’m having the same issue here, stuck on midori telling me connection refused…
            Im working on a pi zero w with jessie lite
            R 1 Reply Last reply
            • R
              RV @bbdv
              @bbdv @ottobot @d-sanchez i hope one of you, has found a solution for this problem?!
              i have the same
              • B
                bbdv
                I have managed to get it working by adjusting the start up script in the etc/init.d/ directory:
                Instead of:
                cd ~/MagicMirror
                I changed it to :
                cd /home/pi/MagicMirror
                Worked great for over 2 week… until I updated MagicMirror, the same error returned…
                (Connection refused)
                M 1 Reply Last reply
                • B
                  bbdv
                  This post is deleted!
                  • B
                    bbdv
                    • B
                      bbdv
                      Got it back to work by starting all over.
                      Here are my* notes/steps:
                      *)I have gathered all these steps from all the contributers on this site.
                      Start with a fresh Jessie lite image…
                      sudo apt-get update
                      sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
                      sudo dpkg -i node_latest_armhf.deb
                      sudo apt-get install npm
                      sudo apt-get install git
                      cd /home/pi/
                      git clone https://github.com/MichMich/MagicMirror
                      cd MagicMirror
                      sudo npm install (This will take 30+ minutes)
                      sudo apt-get install midori
                      sudo apt-get install unclutter
                      sudo aptitude install xinit
                      sudo apt-get install matchbox
                      sudo nano /etc/init.d/startMagicMirror.sh
                      #!/bin/bash
                      ### BEGIN INIT INFO
                      # Provides:          startMagicMirror.sh
                      # Short-Description: startMM
                      # Description:       starts MM
                      ### END INIT INFO
                      node serveronly &
                      sleep 20
                      sudo xinit /home/pi/startMidori.sh
                      sudo chmod a+x /etc/init.d/startMagicMirror.sh
                      sudo update-rc.d startMagicMirror.sh defaults 100
                      sudo apt-get install x11-xserver-utils
                      sudo nano /home/pi/startMidori.sh
                      #!/bin/sh
                      xset -dpms # disable DPMS (Energy Star) features.
                      xset s off # disable screen saver
                      xset s noblank # don’t blank the video device
                      matchbox-window-manager &
                      unclutter &
                      midori -e Fullscreen -a http://localhost:8080
                      sudo chmod a+x /home/pi/startMidori.sh
                      sudo reboot
                      J 1 Reply Last reply
                      Reply Quote 1
                      • J
                        janth @bbdv
                        @bbdv did you use Jessie or Stretch for that?
                        • M
                          meyraa @bbdv
                          @bbdv I had the same problem. Midori has problems with ES6 and the arrow functions. I just deinstalled Midori and installed chromium-browser.
                          You can rewrite the startMidori.sh
                          #!/bin/sh
                          unclutter &
                          chromium-browser --no-sandbox --disable-infobars --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                          If you want you can rename startMidori.sh to startChromium.sh, but don’t forget to rename it in the startMagicMirror.sh too.
                          My startMagicMirror.sh looks like this:
                          #! /bin/bash
                          cd ~/MagicMirror
                          node serveronly &
                          sleep 45
