    midori cant connect to localhost
    11 Posts 6 Posters 11.9k Views 7 Watching
    • O Offline
      ottobot
      Got magicmirror to start on a pi zero following instrustions that I found on this forum. Now when midori starts I’m getting a connection refused on localhost:8080. I can ping localhost fine from terminal and I’ve added /120 in my whitelist.
        d-sanchez
        Did you figure out this error? I’m having the same problem
        • O Offline
          ottobot
          Honestly, I didn’t. I spent a few days off and on trying to get things going, finally I reached out to someone on the forum that had a working image and used that. I have a few more zero’s floating around though and I’m planning on trying again from scratch this weekend.
            bbdv
            Hi Guy’s, I’m having the same issue here, stuck on midori telling me connection refused…
            Im working on a pi zero w with jessie lite
              RV @bbdv
              @bbdv @ottobot @d-sanchez i hope one of you, has found a solution for this problem?!
              i have the same
                bbdv
                I have managed to get it working by adjusting the start up script in the etc/init.d/ directory:
                Instead of:
                I changed it to :
                cd /home/pi/MagicMirror
                Worked great for over 2 week… until I updated MagicMirror, the same error returned…
                (Connection refused)
                  bbdv
                    bbdv
                      bbdv
                      Got it back to work by starting all over.
                      Here are my* notes/steps:
                      *)I have gathered all these steps from all the contributers on this site.
                      Start with a fresh Jessie lite image…
                      sudo apt-get update
                      sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
                      sudo dpkg -i node_latest_armhf.deb
                      sudo apt-get install npm
                      sudo apt-get install git
                      cd /home/pi/
                      git clone https://github.com/MichMich/MagicMirror
                      cd MagicMirror
                      sudo npm install (This will take 30+ minutes)
                      sudo apt-get install midori
                      sudo apt-get install unclutter
                      sudo aptitude install xinit
                      sudo apt-get install matchbox
                      sudo nano /etc/init.d/startMagicMirror.sh
                      #!/bin/bash
                      ### BEGIN INIT INFO
                      # Provides:          startMagicMirror.sh
                      # Short-Description: startMM
                      # Description:       starts MM
                      ### END INIT INFO
                      node serveronly &
                      sleep 20
                      sudo xinit /home/pi/startMidori.sh
                      sudo chmod a+x /etc/init.d/startMagicMirror.sh
                      sudo update-rc.d startMagicMirror.sh defaults 100
                      sudo apt-get install x11-xserver-utils
                      sudo nano /home/pi/startMidori.sh
                      #!/bin/sh
                      xset -dpms # disable DPMS (Energy Star) features.
                      xset s off # disable screen saver
                      xset s noblank # don’t blank the video device
                      matchbox-window-manager &
                      unclutter &
                      midori -e Fullscreen -a http://localhost:8080
                      sudo chmod a+x /home/pi/startMidori.sh
                      sudo reboot
                        janth @bbdv
                        @bbdv did you use Jessie or Stretch for that?
                          meyraa @bbdv
                          @bbdv I had the same problem. Midori has problems with ES6 and the arrow functions. I just deinstalled Midori and installed chromium-browser.
                          You can rewrite the startMidori.sh
                          #!/bin/sh
                          unclutter &
                          chromium-browser --no-sandbox --disable-infobars --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                          If you want you can rename startMidori.sh to startChromium.sh, but don’t forget to rename it in the startMagicMirror.sh too.
                          My startMagicMirror.sh looks like this:
                          #! /bin/bash
                          node serveronly &
                          sleep 45
