    midori cant connect to localhost
    11 Posts 6 Posters 12.6k Views 7 Watching
      d-sanchez
      Did you figure out this error? I’m having the same problem
      • O
        ottobot
        Honestly, I didn’t. I spent a few days off and on trying to get things going, finally I reached out to someone on the forum that had a working image and used that. I have a few more zero’s floating around though and I’m planning on trying again from scratch this weekend.
          bbdv
          Hi Guy’s, I’m having the same issue here, stuck on midori telling me connection refused…
          Im working on a pi zero w with jessie lite
          R 1 Reply Last reply
            RV @bbdv
            @bbdv @ottobot @d-sanchez i hope one of you, has found a solution for this problem?!
            i have the same
              bbdv
              I have managed to get it working by adjusting the start up script in the etc/init.d/ directory:
              Instead of:
              I changed it to :
              cd /home/pi/MagicMirror
              Worked great for over 2 week… until I updated MagicMirror, the same error returned…
              (Connection refused)
              M 1 Reply Last reply
                bbdv
                  bbdv
                    bbdv
                    Got it back to work by starting all over.
                    Here are my* notes/steps:
                    *)I have gathered all these steps from all the contributers on this site.
                    Start with a fresh Jessie lite image…
                    sudo apt-get update
                    sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
                    sudo dpkg -i node_latest_armhf.deb
                    sudo apt-get install npm
                    sudo apt-get install git
                    cd /home/pi/
                    git clone https://github.com/MichMich/MagicMirror
                    cd MagicMirror
                    sudo npm install (This will take 30+ minutes)
                    sudo apt-get install midori
                    sudo apt-get install unclutter
                    sudo aptitude install xinit
                    sudo apt-get install matchbox
                    sudo nano /etc/init.d/startMagicMirror.sh
                    #!/bin/bash
                    ### BEGIN INIT INFO
                    # Provides:          startMagicMirror.sh
                    # Short-Description: startMM
                    # Description:       starts MM
                    ### END INIT INFO
                    node serveronly &
                    sleep 20
                    sudo xinit /home/pi/startMidori.sh
                    sudo chmod a+x /etc/init.d/startMagicMirror.sh
                    sudo update-rc.d startMagicMirror.sh defaults 100
                    sudo apt-get install x11-xserver-utils
                    sudo nano /home/pi/startMidori.sh
                    #!/bin/sh
                    xset -dpms # disable DPMS (Energy Star) features.
                    xset s off # disable screen saver
                    xset s noblank # don’t blank the video device
                    matchbox-window-manager &
                    unclutter &
                    midori -e Fullscreen -a http://localhost:8080
                    sudo chmod a+x /home/pi/startMidori.sh
                    sudo reboot
                    J 1 Reply Last reply
                      janth @bbdv
                      @bbdv did you use Jessie or Stretch for that?
                        meyraa @bbdv
                        @bbdv I had the same problem. Midori has problems with ES6 and the arrow functions. I just deinstalled Midori and installed chromium-browser.
                        You can rewrite the startMidori.sh
                        #!/bin/sh
                        unclutter &
                        chromium-browser --no-sandbox --disable-infobars --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                        If you want you can rename startMidori.sh to startChromium.sh, but don’t forget to rename it in the startMagicMirror.sh too.
                        My startMagicMirror.sh looks like this:
                        #! /bin/bash
                        node serveronly &
                        sleep 45
