    Electron exited with signal SIGILL error
    3 Posts 2 Posters 1.3k Views 2 Watching
      rslohs
      Hello,
      Have had my MM running for a few weeks. Been playing with PM2 a bit to try and learn that. Had the mirror running, came back about a day later and my RPi desktop screen was showing (MM closed). Tried PM2 logs and was getting a electron error. Stopped PM2 and tried to run MM via ‘npm run start’. I’m getting the error seen below, any suggestions? I changed nothing from when it was running properly.
      pi@raspberrypi:~ $ cd ~/MagicMirror
      pi@raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.18.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGILL
      What is SIGILL and how do I resolve? Thanks
        sdetweil @rslohs
        @rslohs sigil
        https://support.sas.com/documentation/onlinedoc/ccompiler/doc700/html/lr1/z2005346.htm
        basically, something tried to execute data, instead of code.
        I don’t know what would cause this
          rslohs
          reinstalled MM and back in business, who knows what happened
