    Issue with PIR Sensor after upgrade to 2.19
    12 Posts 4 Posters 2.9k Views 4 Watching
    • karsten13K Online
      karsten13 @sdetweil
      yes, MMM-PIR-Sensor is deprecated so its better to use another module which is still maintained.
      I got MMM-PIR-Sensor installed with this workaround:
      Change dependencies section in package.json to
        "dependencies": {
          "onoff": "latest",
          "magicmirror-rebuild": "latest"
      Run npm install which will fail.
      Edit node_modules/epoll/binding.gyp and insert the following in line 2 (after the first {):
        "variables": {
          "openssl_fips" : "0"
      Run npm install again.
      • O Offline
        OliWer
        Thanks for your help =)
        I was not able to get MMM-PIR-Sensor running, even with your steps listed above. As it is deprecated I did what @karsten13 suggested and used another PIR (MMM-PIR). It had the same issue first, but using magicmirror-rebuild from https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1 I was able to got the PIR working again.
        So again: Thanks for trying to help and your suggestions!
