    NEWSFEED - Impossible to display full article
    6 Posts 2 Posters 1.5k Views 2 Watching
      selyjohns
      Hello everyone,
      I want to see details of current news displayed with notification ARTICLE_MORE_DETAIL or ARTICLE_TOGGLE_FULL notification, but this is not functionnal (just display black screen)
      Logs
      0 | mm
      (node:26811) electron: Failed to load URL: https://XXX  with error:ERR_BLOCKED_BY_RESPONSE
      I think this is because the website block iframe to avoid click-jacking (https://stackoverflow.com/questions/48668767/error-when-loading-an-external-url-in-an-iframe-with-electron), so there is no possibilities in this case ?
      Thank you for your help !
        sdetweil @selyjohns
        @selyjohns try changing the
        address:“localhost”,
        to
        address::“your local machinbe ip address”,
        my pi is 192.168.2.44
        so
        address:“192.168.,2.44”,
          selyjohns @sdetweil
          Thank you for your reply.
          I don’t undersrand where you want I’ll do this change ?
          Thank you
            sdetweil @selyjohns
            @selyjohns in the MagicMirror config.js
              selyjohns @sdetweil
              @sdetweil I think you speak about the address parameter in the let config
              let config = {
                      address: "0.0.0.0",     // Address to listen on, can be:
                      port: 8080,
              Was 0.0.0.0, replace with local IP of the Pi, but not better…
                selyjohns
                Try it with this RSS feed : https://actu.fr/toulouse/rss.xml
                Did you successful display article in an iframe ?
