    Black Screen after installation MyCalendar
    21 Posts 4 Posters 12.9k Views 4 Watching
      SARCux
      after installation MyCalendar and configure the config.js with
      			module: "MMM-MyCalendar",
      			position: "top_center",
      			classes: "default everyone",
      			header: "Upcoming",
      			disabled: false,
      					colored: true,
      					maximumNumberOfDays: 30,
      					maximumEntries: 10,
      					fade: false,
      					maxTitleLength: 500,
      					useRelativeDates: false,
      					dayOfWeekFormat: "dddd",
      					timeFormat: "HH:mm [Uhr]",
      					dateFormat: "MMMM D",
      					joiningWord: "at",
      					urgency: 1,
      							url: "https://outlook.office365.com/owa/calendar/......./calendar.ics",
      							color: "#ffb350"
      and start pm2 the screen ist black.
      disable the module all works well.
      can anybody help???
      S B 2 Replies Last reply Reply Quote 0
        sdetweil @SARCux
        @SARCux see
          SARCux @sdetweil
          now i use your script
           bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          No LSB modules are available.
          doing test run = true, NO updates will be applied!
          update log will be in /home/pi/MagicMirror/installers/upgrade.log
          Check current Node installation ...
          Node currently installed. Checking version number.
          Minimum Node version: v16.9.1
          Installed Node version: v16.15.0
          No Node.js upgrade necessary.
          Check current NPM installation ...
          NPM currently installed. Checking version number.
          Minimum npm version: V7.11.2
          Installed npm version: V8.5.5
          No npm upgrade necessary.
          saving custom.css
          upgrading from version 2.19.0 to 2.19.0
          fetching latest revisions
          there are 2 local files that are different than the master repo
             installers/mm.sh
             package-lock.json
          any *-lock.json files do not need to be saved
          do you want to save these files for later   (Y/n)?Y
          Checking for modules with removed libraries
                   require for valid-url in module MMM-MyCalendar not found in package.json package.json for module MMM-MyCalendar
                            bypass installing valid-url for module MMM-MyCalendar , doing test run
          processing dependency changes for active modules with package.json files
          processing for module MMM-bsh-tides please wait
          skipped processing for MMM-bsh-tides, doing test run
          processing complete for module MMM-bsh-tides
          processing for module MMM-OpenWeatherForecast please wait
          skipped processing for MMM-OpenWeatherForecast, doing test run
          processing complete for module MMM-OpenWeatherForecast
          restoring custom.css
          test run, restoring files stashed
            sdetweil @SARCux
            @SARCux that is test update
            but u have latest already
              SARCux @sdetweil
              but still a black screen when I activate the module
                sdetweil @SARCux
                @SARCux yes, read the link,
                find the error message,
                get the library name,
                and then install the missing library
                  SARCux @sdetweil
                  I don’t know what to look for and where. SORRY
                    SARCux @sdetweil
                    I cannot find the it.
                    :tired_face: :sleepy_face: :sneezing_face:
                      sdetweil @SARCux
                      @SARCux how do you start MagicMirror?
                      npm start
                      or
                      pm2 starts at boot?
                        SARCux @sdetweil
                        pm2 starts at boot
                        at the moment with
                        pm2 start 0
                        or
                        pm2 stop 0
                          sdetweil @SARCux
                          @SARCux so, pm2 logs --lines=50 to dump the messages
                            SARCux @sdetweil
                            [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                            /home/pi/.pm2/pm2.log last 50 lines:
                            PM2        | 2022-04-30T18:34:18: PM2 log: ===============================================================================
                            PM2        | 2022-04-30T18:34:18: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                            PM2        | 2022-04-30T18:34:18: PM2 log: Time                 : Sat Apr 30 2022 18:34:18 GMT+0200 (Mitteleuropäische Sommerzeit)
                            PM2        | 2022-04-30T18:34:18: PM2 log: PM2 version          : 5.2.0
                            PM2        | 2022-04-30T18:34:18: PM2 log: Node.js version      : 16.15.0
                            PM2        | 2022-04-30T18:34:18: PM2 log: Current arch         : arm
                            PM2        | 2022-04-30T18:34:18: PM2 log: PM2 home             : /home/pi/.pm2
                            PM2        | 2022-04-30T18:34:18: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                            PM2        | 2022-04-30T18:34:18: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                            PM2        | 2022-04-30T18:34:18: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                            PM2        | 2022-04-30T18:34:18: PM2 log: Application log path : /home/pi/.pm2/logs
                            PM2        | 2022-04-30T18:34:18: PM2 log: Worker Interval      : 30000
                            PM2        | 2022-04-30T18:34:18: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                            PM2        | 2022-04-30T18:34:18: PM2 log: Concurrent actions   : 2
                            PM2        | 2022-04-30T18:34:18: PM2 log: SIGTERM timeout      : 1600
                            PM2        | 2022-04-30T18:34:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T18:34:18: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T18:39:52: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T18:39:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T18:39:53: PM2 log: pid=1014 msg=process killed
                            PM2        | 2022-04-30T18:45:45: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T18:45:45: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T19:43:43: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T19:43:43: PM2 log: pid=1859 msg=failed to kill - retrying in 100ms
                            PM2        | 2022-04-30T19:43:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T19:43:43: PM2 log: pid=1859 msg=process killed
                            PM2        | 2022-04-30T19:44:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T19:44:27: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T19:44:47: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T19:44:47: PM2 log: pid=2586 msg=failed to kill - retrying in 100ms
                            PM2        | 2022-04-30T19:44:47: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T19:44:48: PM2 log: pid=2586 msg=process killed
                            PM2        | 2022-04-30T19:56:10: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T19:56:10: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T19:56:37: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T19:56:37: PM2 log: pid=2916 msg=failed to kill - retrying in 100ms
                            PM2        | 2022-04-30T19:56:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T19:56:37: PM2 log: pid=2916 msg=process killed
                            PM2        | 2022-04-30T19:57:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T19:57:51: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T19:58:23: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T19:58:24: PM2 log: pid=3093 msg=failed to kill - retrying in 100ms
                            PM2        | 2022-04-30T19:58:24: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T19:58:24: PM2 log: pid=3093 msg=process killed
                            PM2        | 2022-04-30T19:58:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-04-30T19:58:51: PM2 log: App [MagicMirror:0] online
                            PM2        | 2022-04-30T19:59:06: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-04-30T19:59:06: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-04-30T19:59:06: PM2 log: pid=3291 msg=process killed
                            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                            0|MagicMir | [30.04.2022 19:57.55.534] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:57.55.536] [LOG]   Module helper loaded: MMM-bsh-tides
                            0|MagicMir | [30.04.2022 19:57.55.788] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:57.55.790] [LOG]   Module helper loaded: calendar
                            0|MagicMir | [30.04.2022 19:57.55.792] [LOG]   No helper found for module: MMM-OpenmapWeather.
                            0|MagicMir | [30.04.2022 19:57.55.912] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:57.55.913] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                            0|MagicMir | [30.04.2022 19:57.56.208] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:57.56.209] [LOG]   Module helper loaded: MMM-CalendarExt2
                            0|MagicMir | [30.04.2022 19:57.56.210] [LOG]   All module helpers loaded.
                            0|MagicMir | [30.04.2022 19:57.56.379] [LOG]   Starting server on port 8080 ...
                            0|MagicMir | [30.04.2022 19:57.56.406] [LOG]   Server started ...
                            0|MagicMir | [30.04.2022 19:57.56.408] [LOG]   Connecting socket for: updatenotification
                            0|MagicMir | [30.04.2022 19:57.56.409] [LOG]   Starting module helper: updatenotification
                            0|MagicMir | [30.04.2022 19:57.56.418] [LOG]   Connecting socket for: MMM-bsh-tides
                            0|MagicMir | [30.04.2022 19:57.56.419] [LOG]   Starting module helper: MMM-bsh-tides
                            0|MagicMir | [30.04.2022 19:57.56.421] [LOG]   Connecting socket for: calendar
                            0|MagicMir | [30.04.2022 19:57.56.422] [LOG]   Starting node helper for: calendar
                            0|MagicMir | [30.04.2022 19:57.56.423] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                            0|MagicMir | [30.04.2022 19:57.56.425] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                            0|MagicMir | [30.04.2022 19:57.56.427] [LOG]   Connecting socket for: MMM-CalendarExt2
                            0|MagicMir | [30.04.2022 19:57.56.428] [LOG]   Sockets connected & modules started ...
                            0|MagicMir | [30.04.2022 19:57.56.847] [LOG]   Launching application.
                            0|MagicMir | [30.04.2022 19:58.01.548] [LOG]   Create new calendarfetcher for url: https://outlook.office365.com/owa/calendar/......................../calendar.ics - Interval: 300000
                            0|MagicMir | [30.04.2022 19:58.02.351] [INFO]  Calendar-Fetcher: Broadcasting 21 events.
                            0|MagicMir |
                            0|MagicMir | > magicmirror@2.19.0 start
                            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                            0|MagicMir |
                            0|MagicMir | [30.04.2022 19:58.55.121] [LOG]   Starting MagicMirror: v2.19.0
                            0|MagicMir | [30.04.2022 19:58.55.133] [LOG]   Loading config ...
                            0|MagicMir | [30.04.2022 19:58.55.144] [LOG]   Loading module helpers ...
                            0|MagicMir | [30.04.2022 19:58.55.158] [LOG]   No helper found for module: alert.
                            0|MagicMir | [30.04.2022 19:58.55.187] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.190] [LOG]   Module helper loaded: updatenotification
                            0|MagicMir | [30.04.2022 19:58.55.193] [LOG]   No helper found for module: clock.
                            0|MagicMir | [30.04.2022 19:58.55.231] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.233] [LOG]   Module helper loaded: MMM-bsh-tides
                            0|MagicMir | [30.04.2022 19:58.55.479] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.481] [LOG]   Module helper loaded: calendar
                            0|MagicMir | [30.04.2022 19:58.55.509] [LOG]   Loading module helpers ...
                            0|MagicMir | [30.04.2022 19:58.55.511] [LOG]   No helper found for module: alert.
                            0|MagicMir | [30.04.2022 19:58.55.513] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.514] [LOG]   Module helper loaded: updatenotification
                            0|MagicMir | [30.04.2022 19:58.55.516] [LOG]   No helper found for module: clock.
                            0|MagicMir | [30.04.2022 19:58.55.518] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.519] [LOG]   Module helper loaded: MMM-bsh-tides
                            0|MagicMir | [30.04.2022 19:58.55.520] [LOG]   Initializing new module helper ...
                            0|MagicMir | [30.04.2022 19:58.55.521] [LOG]   Module helper loaded: calendar
                            0|MagicMir | [30.04.2022 19:58.55.962] [LOG]   Launching application.
                            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                            0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                            0|MagicMir | -
                            0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                            0|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1105)
                            0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
                            0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13343)
                            0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                            0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
                            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js:2:15)
                            0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                            0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                            0|MagicMir | [30.04.2022 19:58.55.535] [ERROR] Whoops! There was an uncaught exception...
                            0|MagicMir | [30.04.2022 19:58.55.546] [ERROR] Error: Cannot find module 'request'
                            0|MagicMir | Require stack:
                            0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js
                            0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js
                            0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
                            0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js
                            0|MagicMir | - /home/pi/MagicMirror/js/app.js
                            0|MagicMir | - /home/pi/MagicMirror/js/electron.js
                            0|MagicMir | -
                            0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
                            0|MagicMir |   code: 'MODULE_NOT_FOUND',
                            0|MagicMir |   requireStack: [
                            0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js',
                            0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js',
                            0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js',
                            0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                            0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
                            0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
                            0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            0|MagicMir |     undefined
                            0|MagicMir |   ]
                            0|MagicMir | }
                            0|MagicMir | [30.04.2022 19:58.55.549] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMir | [30.04.2022 19:58.55.550] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            0|MagicMir | [3346:0430/195856.732859:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
                            0|MagicMir | [3376:0430/195856.878771:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
                            0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                            S mumblebajM 2 Replies Last reply Reply Quote 0
                              sdetweil @SARCux
                              • mumblebajM Offline
                                mumblebaj Module Developer @SARCux
                                @SARCux said in Black Screen after installation MyCalendar:
                                https://outlook.office365.com/owa/calendar/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                Hi. Never post your logs without blanking out your personal information, keys, passwords etc. With the information you posted, everybody can access your personal calendar information.
                                  SARCux @mumblebaj
                                  @mumblebaj
                                  edit.
                                  Thx
                                    sdetweil @SARCux
                                    @SARCux did u get it working?
                                      BrotherDan @SARCux
                                      @SARCux
                                      I am quite a novice with MagicMirror, but I have seen this type of behavior when I failed to add the needed dependencies…
                                      BrotherDan
                                        SARCux @sdetweil
                                        unfortunately not
                                        mumblebajM S 2 Replies Last reply Reply Quote 0
                                          @SARCux You are missing a module in the MMM-MyCalendar folder as shown by the sreenshot that @sdetweil posted.
                                          See the following link for steps on how to fix it.
                                          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/10?page=1
                                            sdetweil @SARCux
                                            @SARCux so, could you read back the instructions I sent, in the same link as @mumblebaj .
                                            if they are not in your native language, use Google translate to convert them
