    Newfeed & Bring not updating
    4 Posts 2 Posters 801 Views 2 Watching
      MDLefevere
      Hello :) ,
      My MagicMirror has been running smooth for about two months.
      Just recently, my Newfeed and Bring module have stopped updating.
      When i use “pm2 log” i get the following error’s, but only from the Bring module.
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       | [19.06.2022 14:36.21.701] [ERROR] If you think this really is an is        sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss        ues
      0|mm       | [19.06.2022 14:50.21.697] [ERROR] Whoops! There was an uncaught exc        eption...
      0|mm       | [19.06.2022 14:50.21.699] [ERROR] TypeError: Cannot read properties        of undefined (reading 'locale')
      0|mm       |     at BringClient._init (/home/pi/MagicMirror/modules/MMM-Bring/Br        ingClient.js:28:18)
      0|mm       |     at new BringClient (/home/pi/MagicMirror/modules/MMM-Bring/Brin        gClient.js:23:14)
      0|mm       |     at Class.initClient (/home/pi/MagicMirror/modules/MMM-Bring/nod        e_helper.js:49:23)
      0|mm       |     at Class.getList (/home/pi/MagicMirror/modules/MMM-Bring/node_h        elper.js:39:18)
      0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modul        es/MMM-Bring/node_helper.js:18:22)
      0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:1        09:11)
      0|mm       |     at Socket.emit (node:events:394:28)
      0|mm       |     at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket        .io/dist/typed-events.js:69:22)
      0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:4        66:39
      0|mm       |     at processTicksAndRejections (node:internal/process/task_queues        :78:11)
      0|mm       | [19.06.2022 14:50.21.702] [ERROR] MagicMirror will not quit, but it        might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | [19.06.2022 14:50.21.704] [ERROR] If you think this really is an is        sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss        ues
      The config i have used for my newsfeed is:
                              module: "newsfeed",
                              position: "middle_center", //of op de lower_third
                                      feeds: [
                                                      title: "Nu.nl",
                                                      url: "https://nu.nl/rss/Algemeen"
                                      showSourceTitle: false,
                                      showDescription: true,
                                      showPublishDate: false,
                                      broadcastNewsFeeds: false,
                                      broadcastNewsUpdates: false,
                                      ignoreOldItems: true,
                                      updateInterval: 20000, // 20 seconden
                                      ignoreOlderThan: 21600000, // Dit is 6 uur
                                      reloadInterval: 780000, // 13 minuten
      What am i missing?
        MDLefevere @MDLefevere
        Maybe it’s just as it should, but when i give mm.sh a restart, i see what it looks like 3 “mm” processes
          sdetweil @MDLefevere
          @MDLefevere u have three instances defined
          use pm2 delete 0 and pm2 delete 1
          then pm2 save to record that
          to get rid of the extras
          then pm2 restart all
            MDLefevere @sdetweil
            Many thanks!.
            That seemed to work so far :) !
