    Can't cloon the repository
    5 Posts 2 Posters 971 Views 2 Watching
    • P
      Purple
      I am very new on Magic Mirror and want to start building a smart mirror. I have a Odroid and already installed Nodejs. And now I want to go further with the second step on the installation manual. Clooning the repository.
      When I give this command; git clone https://github.com/MichMich/MagicMirror
      I get the following message: bash: git: command not found.
      Anyone knows what to do?
        sdetweil @Purple
        @Purple u have to install git too…
        best to use my script which does all the setup
        see
          sdetweil @Purple
          @Purple I run mm on an odroid xu4 every day
          • P
            Purple @sdetweil
            Thnx. I am a real beginner. So do I have to run all the scrips that are on your page?
              sdetweil @Purple
              @Purple no, you run install
              then every 3 months when we release a new version on mm you run the upgrade
              others are for if u change your mind
              if English isn’t your primary language, translate the page
