    Two color font?
    13 Posts 5 Posters 3.9k Views 5 Watching
      sdetweil @ember1205
      @ember1205 everything goes in custom.css you don’t need to change anything else as it would break a module’s ability to update
      the dev window shows you where (file) a class comes from. but u don’t edit that file
      you can change by adding/editing in the top window in elements mode.
      css is hierarchical
      last one in wins
      main.css is first
      module specific css is next
      custom.css is last, it overrides anything above
      so if u wanted to add shadow to .small from main.css
      in costum.css
      .small {
      whatever required
      done, custom.css wins.
      but it might be tedious to find every element class as there is no enforcement for using the mm provided classes…
        rubelahamed
        @MMRIZE said in Two color font?:
        I think most efficient and easiest way is using text-shadow dropping.
          sdetweil @rubelahamed
          @rubelahamed and?
