    MMM-AVStock does not display stock info
    5 Posts 3 Posters 1.3k Views 3 Watching
    • F Offline
      fulviolcabrera
      I have tried to uninstall, reinstall, installed a new API Key, not sure what else to check, its connected to the network as other modules work fine. eg: Spotify, Weather etc. Any clues? Please
        bioart @fulviolcabrera
        @fulviolcabrera I have the same problem. Even got a new API key and same problem.
          sdetweil @bioart
          @bioart when I run it with my free AV key I see in the console log
          [07.12.2022 15:08.34.461] [ERROR] [MMM-AVStock] ERROR: "An AlphaVantage error occurred. Thank you for using Alpha Vantage! This is a premium endpoint. You may subscribe to any of the premium plans at https://www.alphavantage.co/premium/ to instantly unlock all premium endpoints"
          [07.12.2022 15:08.49.398] [ERROR] (node:890172) UnhandledPromiseRejectionWarning: An AlphaVantage error occurred. Thank you for using Alpha Vantage! This is a premium endpoint. You may subscribe to any of the premium plans at https://www.alphavantage.co/premium/ to instantly unlock all premium endpoints
          [07.12.2022 15:08.49.399] [ERROR] (node:890172) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          I have another app that uses the same library with the free key and it works.
            bioart @sdetweil
            @sdetweil Interesting. I wonder what endpoint changed and if it can just be turned off. I haven’t looked at the module, but I’ll see if I can debug in the next few days
              sdetweil @bioart
              @bioart the module uses an npm lib (in JavaScript), I use one lib function, he uses a different one
