    Can't get MMM-CalendarExt2 module to load
    2 Posts 2 Posters 426 Views 2 Watching
    • K Offline
      katalopapi
      I’m very new to this so bear with me. I’m trying to create a magicMirror for my wife for a Christmas present and I’m having trouble getting MMM-CalendarExt2 to load. I don’t see any errors in the console. It just doesn’t load the module when loading the other modules in my configuration.
      Here’s the console log:
      loader.js:184 Load script: modules/MMM-CalendarExt2/CALEXT2_ViewUpcoming.js
      loader.js:184 Load script: modules/MMM-CalendarExt2/CALEXT2_ViewWeek.js
      loader.js:184 Load script: modules/MMM-CalendarExt2/CALEXT2_ViewWeekly.js
      loader.js:184 Load script: modules/MMM-CalendarExt2/CALEXT2_Legend.js
      loader.js:184 Load script: //code.iconify.design/1/1.0.0-rc3/iconify.min.js
      loader.js:160 Scripts loaded for: MMM-CalendarExt2
      loader.js:203 Load stylesheet: modules/MMM-CalendarExt2/MMM-CalendarExt2.css
      loader.js:162 Styles loaded for: MMM-CalendarExt2
      loader.js:164 Translations loaded for: MMM-CalendarExt2
      loader.js:184 Load script: modules/default/alert/alert.js
      module.js:509 Module registered: alert
      loader.js:155 Bootstrapping module: alert
      loader.js:184 Load script: modules/default/alert/notificationFx.js
      loader.js:160 Scripts loaded for: alert
      loader.js:203 Load stylesheet: vendor/css/font-awesome.css
      loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
      loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
      loader.js:162 Styles loaded for: alert
      translator.js:107 alert - Load translation: translations/en.json
      VM1530 sandbox_bundle:53 Electron Security Warning (Insecure
      Resources) This renderer process loads resources using insecure
      protocols. This exposes users of this app to unnecessary security risks.
      Consider loading the following resources over HTTPS or FTPS.
      • http://code.iconify.design/1/1.0.0-rc3/iconify.min.js
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
      This warning will not show up
      once the app is packaged.
      Content-Security-Policy) This renderer process has either no Content
      Security
      Policy set or a policy with “unsafe-eval” enabled. This exposes users of
      translator.js:107 alert - Load translation fallback: translations/bg.json
      loader.js:164 Translations loaded for: alert
      modules/default/updatenotification/updatenotification.js
      module.js:509 Module registered: updatenotification
      loader.js:155 Bootstrapping module: updatenotification
      loader.js:160 Scripts loaded for: updatenotification
      modules/default/updatenotification/updatenotification.css
      loader.js:162 Styles loaded for: updatenotification
      loader.js:164 Translations loaded for: updatenotification
      loader.js:184 Load script: modules/default/clock/clock.js
      module.js:509 Module registered: clock
      loader.js:155 Bootstrapping module: clock
      loader.js:244 File already loaded: moment.js
      vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
      loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
      loader.js:160 Scripts loaded for: clock
      loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
      loader.js:162 Styles loaded for: clock
      loader.js:164 Translations loaded for: clock
      loader.js:184 Load script: modules/default/weather/weather.js
      module.js:509 Module registered: weather
      loader.js:155 Bootstrapping module: weather
      loader.js:184 Load script: modules/default/weather/weatherprovider.js
      loader.js:184 Load script: modules/default/weather/weatherobject.js
      loader.js:244 File already loaded: suncalc.js
      loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
      loader.js:160 Scripts loaded for: weather
      loader.js:244 File already loaded: font-awesome.css
      vendor/node_modules/weathericons/css/weather-icons.css
      loader.js:203 Load stylesheet: modules/default/weather/weather.css
      loader.js:162 Styles loaded for: weather
      loader.js:164 Translations loaded for: weather
      loader.js:203 Load stylesheet: css/custom.css
      alert.js:47 Starting module: alert
      updatenotification.js:18 Starting module: updatenotification
      clock.js:48 Starting module: clock
      weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
      weatherprovider.js:46 Weather provider: OpenWeatherMap started.
      main.js:501 All modules started!
      Here’s my very simple configuration to get proof of concept:
      module: ‘MMM-CalendarExt2’,
      calendars : [
      url: “http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics”,
      views: [
      mode: “daily”,
      type: “row”,
      position: “bottom_bar”,
      slotCount: 7,
      locale: “en”,
      hideOverflow: false,
      filterPassedEvent: true,
      calendars: [“usHoliday”,],
      scenes: [
      views: [“daily”,],
      module: “alert”,
      module: “updatenotification”,
      position: “top_bar”
      module: “clock”,
      position: “top_left”
      module: “weather”,
      position: “top_right”,
      weatherProvider: “openweathermap”,
      type: “current”,
      locationID: “5577147”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
      apiKey: “92e11e9f351f49fe4c1039ba63f42f76”
      Any ideas?
      TIA
        sdetweil @katalopapi
        @katalopapi ext2 is no longer supported, I recommend u look at EXT3. it gets it’s info from the default calendar. only one app loading cal info.
