    MM funktioniert nicht mehr nach Update
    13 Posts 2 Posters 3.5k Views 2 Watching
    • N Offline
      NickOne @sdetweil
      No LSB modules are available.
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 9.11 (stretch)
      Release: 9.11
      Codename: stretch
        sdetweil @NickOne
        @NickOne yes, latest MM release will not run on stretch.
        only fix is to flash a new sd card and re-setup the mirror
        my backup/restore scripts could help minimize the work …
        you can run them from the web, save the changes to github and then restore from there
        (after installing MM on a new sd card)
        I have just updated my upgrade script to NOT upgrade on stretch systems
        at least give u time to figure out what to do , not break your MM setup
        • N Offline
          NickOne @sdetweil
          Okay, vielen Dank für Ihre Hilfe. Dann werde ich wohl alles neu machen dürfen. Danke für die Links zum backup-restore script. Mal schauen ob ich das alles hinbekomme.
          Schön Abend Ihnen!
