    MMM-Moon, See the moon phases and rise/set times!
    13 Posts 7 Posters 7.1k Views 7 Watching
    • E Offline
      enderflop
      https://github.com/EnderFlop/MMM-Moon
      There’s an indepth README on the GitHub page for anyone interested in installing this. If there is interest I can add more configuration options for customizing the image, but right now all you do is set your location and timezone. Let me know what you think!
      R S halacabullasH 3 Replies Last reply Reply Quote 2
        Rags @enderflop
        @enderflop
        Okay, so i tried it out and it is working fine. Nice effort. However, You have forgotten to add the sample config.js entries, though you have given the configuration options. Is there a way to enlarge the size of the image in the configuration file?
          siboy73 @enderflop
          @enderflop I have given this a try and all i get is the No Image! message. Any ideas?
            Rags @Rags
            @Rags said in MMM-Moon, See the moon phases and rise/set times!:
            @enderflop
            To add lines of code to configure the size of the image, you can modify the getDom function as follows:
            getDom: function() {
              var outerDiv = document.createElement("div");
              if (this.content) {
                var img = document.createElement("img");
                img.src = this.content;
                img.style.width = this.config.width || "100%"; // add this line to set the width of the image
                img.style.height = this.config.height || "auto"; // add this line to set the height of the image
                outerDiv.appendChild(img);
              } else {
                outerDiv.innerText = "No image!";
              return outerDiv;
            add this in config.js;
              module: "MMM-Moon",
                width: "400px",      //    as per requirement
                height: "400px"       //    as per requirement
            code blocks please, by sdetweil
              siboy73 @siboy73
              @enderflop further to before mentioned, I have changed my location in the js file from the standard US location you had and if I leave my location out of the config file I get an image(not sure if this a correct image or generic) but when I add my location in the config I get the no image message.
                sdetweil @Rags
                @Rags a much better way is to use css to set the size instead of changing the code
                  Rags @sdetweil
                  @sdetweil said in MMM-Moon, See the moon phases and rise/set times!:
                  Sure. Understood. Just learning.
                    sdetweil @Rags
                    @Rags its ok, we are all learning every day… i learn new MM stuff every day due to different modules and uses
                    • Z Offline
                      Zippyczech
                      Guys, can somebody please post sample config? Im having troubles setting it up with something else than empty config. Thanks
                      L 2 Replies Last reply Reply Quote 0
                      • L Offline
                        LanceInMN @Zippyczech
                        @Zippyczech
                        I initially put the lat/lon in quotes, but they must be integer values:
                        		module: "MMM-Moon",
                        		//disabled: true,
                        		config:
                        			lat: 44.55555,    // Latitude
                        			lon: -93.55555,   // Longitude
                        			timezone: "America/Chicago"
                        • L Offline
                          @Zippyczech
                          module: “MMM-Moon”,
                          //disabled: true,
                          position: “top_right”,
                          config:
                          timezone: “America/Chicago”
                            sdetweil @LanceInMN
                            @LanceInMN I’m gonna be picky in case someone else reads this and doesn’t pay attention.
                            integers have no decimal places
                            u meant numeric
                            with quotes it’s a text string
                            • halacabullasH Offline
                              halacabullas @enderflop
                              @enderflop i would LOVE LOVE LOVE the feature of customizing the image
