    Moment Timezone has no data for GMT+abcd
    4 Posts 2 Posters 1.2k Views 2 Watching
    • M
      Mystara
      Hi there,
      I’m getting the above error (Moment Timezone has no data for GMT+0100) for certain entries in my calendar. From a look, I think these are all iCal entries that relate to flights. From looking around, I understand that there’s some ‘need’ to create custom timezones for flights where a flight might take off in one timezone and land in another?
      In any case, looking at my calendar file, there appear to be two relevant entries. The first:
      BEGIN:VTIMEZONE
      TZID:GMT+0100
      BEGIN:STANDARD
      TZOFFSETFROM:+0100
      DTSTART:20010101T000000
      TZNAME:GMT+1
      TZOFFSETTO:+0100
      END:STANDARD
      END:VTIMEZONE
      Seems to be creating a new time zone called “GMT+0100”.
      The second entry then seems to use that time zone:
      BEGIN:VEVENT
      CREATED:20220426T192115Z
      UID:20220426T192113Z--386008955@www.britishairways.com
      DTEND;TZID=“GMT+0100”:20220526T072500
      TRANSP:TRANSPARENT
      X-APPLE-TRAVEL-ADVISORY-BEHAVIOR:AUTOMATIC
      SUMMARY:Online Check-in opens for
      LAST-MODIFIED:20220426T192115Z
      DTSTAMP:20220426T192112Z
      DTSTART;TZID=“GMT+0100”:20220526T072500
      SEQUENCE:0
      DESCRIPTION:
      END:VEVENT
      And I’m guessing it’s this latter entry that causes MM to raise the above error.
      Any thoughts on how to fix this (besides removing the entry from my calendar)?
        sdetweil @Mystara
        @Mystara yes, Microsoft has messed it up again.
        they have changed the format, to another non standard format.
        I’ve fixed it twice so far. unfortunately this is in the Ical parser library we use. I won’t be able to get this done before the next mm release on April 1.
        nobody but Microsoft supports custom timezones.
          sdetweil @Mystara
          @Mystara said in Moment Timezone has no data for GMT+abcd:
          actually this is worse than any of the others… because they USED to clarify that this was a custom timezone, now they don’t…
          the open issue
          https://github.com/jens-maus/node-ical/issues/246
          where the choices before were
          if (tz === ‘tzone://Microsoft/Custom’ || tz===‘Customized Time Zone’) {
          now there is nothing…
          the list of standardised timezones is
          https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
          • M
            Mystara @sdetweil
            @sdetweil Thanks for looking. Classic Microsoft behaviour :)
