    Install MagicMirror on Orange Pi Lite (Armbian)
    5 Posts 3 Posters 5.4k Views 3 Watching
    • T Offline
      thanhtantran
      Hello,
      I installed MagicMirror on Orange Pi Lite. Got error in this
      npm ERR! Linux 3.4.113-sun8i
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! node v4.2.6
      npm ERR! npm  v3.5.2
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! electron@1.4.15 postinstall: `node install.js`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the electron@1.4.15 postinstall script 'node install.js'.
      npm ERR! If you do, this is most likely a problem with the electron package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR!     npm bugs electron
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls electron
      is that the node version and npm version is wrong? Which version I should install?
      kylelmartinK 1 Reply Last reply Reply Quote 0
      • kylelmartinK Offline
        kylelmartin @thanhtantran
        Sorry - have no help for you, but I’m really interested to see if you can get this to work on a $15 board.
        Thanks for giving it a shot.
        • G Offline
          GustavoALara
          Hi friends
          I had the same problem using the NPM 3.2 and NODE 6.10 versions with an OPI Lite.
          For fix I downgrade the versions to NODE 5.10 and NPM 2.4, run the installation again and everything works fine.
          • T Offline
            thanhtantran @GustavoALara
            @GustavoALara Can you help on instruction to downgrade npm and node to 5.10 and 2.4?
            • G Offline
              GustavoALara
              Changing node version
              sudo npm cache clean -f
              sudo npm install -g n
              sudo n 5.1.0
              Changing npm version
              npm install -g npm@2.4.0
