    pm2 no longer launching MM
    38 Posts 3 Posters 14.9k Views 3 Watching
      sdetweil @JMac
      @JMac said in pm2 no longer launching MM:
      I had an extended calendar module
      what is the name of that module?
        JMac
        I had 2 versions of the PIR sensor module as one didn’t work, I don’t know if I ended up using the lite version or the other one.
        some of the modules are saying they have old lockfiles (this is for the ISS module) or in the case of dad jokes it has an ERR! code eresolve.
        Any ideas why the calendar extension hasn’t popped back up? It was calendar ext2 I was using I think.
          sdetweil @JMac
          no idea… but one might look at the logs
            sdetweil @JMac
            @JMac ignore the lockfiles message…
            modules shouldn’t ship lock files… (in my opinion)
              JMac
              Sam, scratch my last message, I was just about to turn everything off as it’s getting pretty late here.
              used ctrl c to stop the MM so I could shutdown the pi and attack it another day.
              pm2 restarted the MM and hey presto the mirror seems by and large back to normal.
              I’m away with work for the next 3 days but will have a proper butchers (look) when I’m back home.
              Thank you so much for both your patience and help.
              I had genuine fears I’d have to start the entire build (modules bit) again and I was lucky I got it up and running like I did in the first place.
              thank you!
                JMac
                Thought I’d drop in here rather than start a new thread, with this current setup pm2 stop mm in terminal no longer stops the mirror from relaunching after using shift+Q.
                Any ideas how I stop the MM to allow me to shut the pi down safely for a brief time?
                  sdetweil @JMac
                  @JMac pm2’s JOB is to keep the apps it manages running. so if YOU stop it, or it crashes doesn’t matter , same job, restart the app.
                  to stop a managed app. you need to use the pm2 command
                  so, minimize the app, ctrl-m for mm
                  open a terminal window on the desktop, ctrl-alt-t, and type
                  pm2 status
                  and get the name or number of the app you are interested in and then do
                  pm2 stop x
                  where x is the name or number
                  most Linux commands have help built in by convention
                  pm2 --help
                  • T Offline
                    TDMPro2K @sdetweil
                    i followed this to get my starting again
                    https://forum.magicmirror.builders/topic/10840/problems-with-starting-pm2-start-mm-sh/7
                    • 4 / 4
