    Repeating Google Calendar invites showing up at wrong time
    7 Posts 2 Posters 1.0k Views 2 Watching
      mholzma
      I have a recurring Google Calendar Event that is supposed to show up at 18:15 however the calendar shows it at 23:15 instead.
      Here is the excerpt from the ICS file.
      BEGIN:VEVENT
      DTSTART;TZID=America/Chicago:20230222T181500
      DTEND;TZID=America/Chicago:20230222T191500
      RRULE:FREQ=WEEKLY
      DTSTAMP:20230426T172808Z
      UID:arhpo9aql0lcctnpcdl0olhevp@google.com
      CLASS:PUBLIC
      CREATED:20220901T003716Z
      DESCRIPTION:
      LAST-MODIFIED:20230426T170307Z
      SEQUENCE:2
      STATUS:CONFIRMED
      SUMMARY:6:15 guitar - Sarah
      TRANSP:OPAQUE
      END:VEVENT
      And here is a picture of the stock calendar module:
      Do I just need to recereate those entries or is something else going on?
        sdetweil @mholzma
        @mholzma what time is your system set to ? we use that as the base for the calendar
          mholzma @sdetweil
          @sdetweil America/Central. The non repeating invites show up correctly.
            sdetweil @mholzma
            @mholzma I am on central time too… and I see 18:15
            in your config.js change this
            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
            to this
            	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
            then start your MM like this from the command line (if using pm2, do a pm2 stop all)
            npm start >somefile.txt
            wait til the calendar is up
            then ctrl-m to minimize MM
            ctrl-c to stop mm
            then edit the somefile.txt
            and look for
            [DEBUG] initial tz=America/Chicago
            [DEBUG] corrected tz=America/Chicago
            let me know…
              mholzma @sdetweil
              @sdetweil, here is the log data I found and nothing seems off.
              [27.04.2023 15:31.17.650] [DEBUG] Event:
              {**<REDACTED>**}
              [27.04.2023 15:31.17.650] [DEBUG] start: Thu Feb 23 2023 00:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.650] [DEBUG] end:: Thu Feb 23 2023 01:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.650] [DEBUG] duration: 3600000
              [27.04.2023 15:31.17.650] [DEBUG] title: 6:15 guitar - Sarah
              [27.04.2023 15:31.17.650] [DEBUG] Search for recurring events between: Thu Apr 27 2023 15:31:17 GMT+0000 (GMT) and Thu Apr 25 2024 23:59:59 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] Title: 6:15 guitar - Sarah, with dates: ["2023-05-04T05:15:00.000Z",**<REDACTED>**]
              [27.04.2023 15:31.17.653] [DEBUG] event.recurrences: undefined
              [27.04.2023 15:31.17.653] [DEBUG]  recurring date is Thu May 04 2023 05:15:00 GMT+0000 (GMT) offset is 0
              [27.04.2023 15:31.17.653] [DEBUG]  recurring date is Thu May 04 2023 05:15:00 GMT+0000 (GMT) offset is 0 Hour is 05
              [27.04.2023 15:31.17.653] [DEBUG] Corrected startDate: Thu May 04 2023 05:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] initial tz=America/Chicago
              [27.04.2023 15:31.17.653] [DEBUG] corrected tz=America/Chicago
              [27.04.2023 15:31.17.653] [DEBUG] start date/time=Thu Feb 23 2023 00:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] start offset=-360
              [27.04.2023 15:31.17.653] [DEBUG] start date/time w tz =Thu Feb 23 2023 00:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] event date=Thu May 04 2023 05:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] event offset=-300 hour=0 event date=Thu May 04 2023 05:15:00 GMT+0000 (GMT)
              [27.04.2023 15:31.17.653] [DEBUG] offset
              [27.04.2023 15:31.17.653] [DEBUG] adjust down 1 hour dst change
              [27.04.2023 15:31.17.654] [DEBUG] adjustHours=-1
              [27.04.2023 15:31.17.654] [DEBUG] duration: 3600000
              [27.04.2023 15:31.17.654] [DEBUG] saving event: false
                sdetweil @mholzma
                @mholzma this is mine
                 recurring date is Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time) offset is 300
                [26.04.2023 18:02.26.846] [DEBUG]  recurring date is Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
                [26.04.2023 18:02.26.846] [DEBUG] new recurring date2 is Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time)
                [26.04.2023 18:02.26.847] [DEBUG] Corrected startDate: Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time)
                [26.04.2023 18:02.26.847] [DEBUG] initial tz=America/Chicago
                [26.04.2023 18:02.26.847] [DEBUG] corrected tz=America/Chicago
                [26.04.2023 18:02.26.847] [DEBUG] start date/time=Wed Feb 22 2023 18:15:00 GMT-0600 (Central Standard Time)
                [26.04.2023 18:02.26.847] [DEBUG] start offset=-360
                [26.04.2023 18:02.26.847] [DEBUG] start date/time w tz =Wed Feb 22 2023 18:15:00 GMT-0600 (Central Standard Time)
                [26.04.2023 18:02.26.847] [DEBUG] event date=Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time)
                [26.04.2023 18:02.26.847] [DEBUG] event offset=-300 hour=19 event date=Wed May 03 2023 19:15:00 GMT-0500 (Central Daylight Time)
                [26.04.2023 18:02.26.847] [DEBUG] offset
                [26.04.2023 18:02.26.847] [DEBUG] adjust down 1 hour dst change
                [26.04.2023 18:02.26.847] [DEBUG] adjustHours=-1
                [26.04.2023 18:02.26.847] [DEBUG] duration: 3600000
                which says your system timezone is set to GMT time,
                  mholzma @sdetweil
                  @sdetweil, you nailed it! Thank you so much.
                  I needed to add a timezone environment variable to my docker container. Thank you so much for pointing that out!
                  Planning to build a display (not smart mirror) for our kitchen and this was the hold up.
