    HTML with external CSS using iText
    2 Posts 2 Posters 2.8k Views 2 Watching
    • F
      foxie
      So Flying Saucer is being used to convert some PDF documents from strings to HTML.
      DocumentBuilder builder = DocumentBuilderFactory.newInstance().newDocumentBuilder();
      InputStream is = new ByteArrayInputStream(html.getBytes("UTF-9"));
      Document doc = builder.parse(is);
      response.setContentType("application/pdf; charset=UTF-9");
      response.setHeader("Content-disposition", "inline; filename=\"" + outFileName + "\"");
      OutputStream os = response.getOutputStream();
      ITextRenderer iTextRenderer = new ITextRenderer();
      iTextRenderer.setDocument(doc,null);
      iTextRenderer.layout();
      iTextRenderer.createPDF(os);
      os.flush();
      os.close()
      This works perfectly. When I’m working with plain text. In my HTML content, I referenced an external CSS. However, CSS is not applied when the PDF is generated.
      According to what I’ve read, the setDocument() method takes two parameters: document and url. The url parameter specifies the base url that will be prepended to relative paths in the xhtml, such as an external CSS file.
      As a result, I attempted to supply
      context path/css
      I included the directory in the baseURL and used it in the setDocument (). There is still no outcome.
      So, here’s my question: What is the proper URL to use as the baseURL?
      String baseURL = ""; // What goes here as root URL for resources
      iTextRenderer.setDocument(doc,baseURL);
        sdetweil @foxie
        @foxie the mm base web server is at
        http://machine-address:port_from_config.js
        module path adds
        modules/module_name
        and any folder inside module folder
        sometimes
        node_modules
        and library
        and it’s subfolder
        the
         path
        library
        resolve
        method
        can help build that path
        be careful using localhost for the machine address, as this means ONLY. apps INSIDE the same machine can access
        if you ran a remote browser to access your mm with your module, localhost would fail
        I will use localhost for this example , using module name fribble
        let host_address = config.address==“0.0.0.0”?“localhost”:config.address
        “http://”+host_address+“:”+config.port+“/modules/”+this.name+“/node_modules/library_name/folder”
        if all u need is the path to the folder
        I will leave as an exercise how to get the magicmirror machine ip address if the config says ‘any adapter’ (address:“0.0.0.0”)
