    ozone_platform_x11.cc(239)] Missing X server or $DISPLAY
    6 Posts 2 Posters 6.7k Views 2 Watching
    • N Offline
      noonas
      I have a RasPi3 with a 7" LCD (DSI connector not HMDI) connected and it works.
      I have a wireless keyboard/mouse and I can use the terminal just fine.
      I have installed MM as per instructions, but when I try to start it it says:
      noonas@HomeassistantPi:~/MagicMirror $ npm run start
      magicmirror@2.23.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [12.06.2023 08:51.04.961] [LOG] Starting MagicMirror: v2.23.0
      [12.06.2023 08:51.04.974] [LOG] Loading config …
      [12.06.2023 08:51.04.989] [DEBUG] config template file not exists, no envsubst
      [12.06.2023 08:51.05.003] [LOG] Loading module helpers …
      [12.06.2023 08:51.05.006] [LOG] No helper found for module: alert.
      [12.06.2023 08:51.05.050] [LOG] Initializing new module helper …
      [12.06.2023 08:51.05.052] [LOG] Module helper loaded: updatenotification
      [12.06.2023 08:51.05.054] [LOG] No helper found for module: clock.
      [12.06.2023 08:51.05.732] [LOG] Initializing new module helper …
      [12.06.2023 08:51.05.734] [LOG] Module helper loaded: calendar
      [12.06.2023 08:51.05.736] [LOG] No helper found for module: compliments.
      [12.06.2023 08:51.05.739] [LOG] No helper found for module: weather.
      [12.06.2023 08:51.05.813] [LOG] Initializing new module helper …
      [12.06.2023 08:51.05.814] [LOG] Module helper loaded: newsfeed
      [12.06.2023 08:51.05.815] [LOG] All module helpers loaded.
      [12.06.2023 08:51.05.844] [LOG] Starting server on port 8080 …
      [3287:0612/085105.875951:ERROR:ozone_platform_x11.cc(239)] Missing X server or $DISPLAY
      [3287:0612/085105.876180:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
      I have tried to set the $DISPLAY variable to 0:0, same error comes.
      What can I do??
        sdetweil @noonas
        @noonas you installed on the lite/text mode only version of Raspberry pi OS
        MM needs the full version with desktop… as the browser uses graphics mode always
        see https://docs.magicmirror.builders/getting-started/requirements.html#hardware
        if you had used my install script it would have stopped because of this and told you
        see
        • N Offline
          noonas @sdetweil
          @sdetweil Thanks, Installed the GUI/Desktop and now it works!!
          Now trying to remove the fat margins of the screen for the modules…
            sdetweil @noonas
            @noonas see the main.css for the margins
            then change by adding entry to custom.css
            • N Offline
              noonas @sdetweil
              @sdetweil said in ozone_platform_x11.cc(239)] Missing X server or $DISPLAY:
              main.css
              Got it, thanks works better now! This is aweome…
              May build my own module.
                sdetweil @noonas
                @noonas see my SampleModule
                https://github.com/sdetweil/SampleModule
                and of course there are a lot to look at
