    MMM-WhisperGPT
    2 Posts 1 Posters 925 Views 1 Watching
    • R
      rmonteroc
      Hi, I am trying to implement this module into my mirror, I’ve setup all dependencies, however I am getting this error after recording the request
      [14.09.2023 12:26.49.147] [ERROR] Error uploading file: AxiosError: connect ECONNREFUSED ::1:80
          at AxiosError.from (/home/pi/MagicMirror/modules/MMM-WhisperGPT/node_modules/axios/dist/node/axios.cjs:836:14)
          at RedirectableRequest.handleRequestError (/home/pi/MagicMirror/modules/MMM-WhisperGPT/node_modules/axios/dist/node/axios.cjs:3010:25)
          at RedirectableRequest.emit (node:events:526:35)
          at eventHandlers.<computed> (/home/pi/MagicMirror/modules/MMM-WhisperGPT/node_modules/follow-redirects/index.js:14:24)
          at ClientRequest.emit (node:events:514:28)
          at Socket.socketErrorListener (node:_http_client:501:9)
          at Socket.emit (node:events:514:28)
          at emitErrorNT (node:internal/streams/destroy:151:8)
          at emitErrorCloseNT (node:internal/streams/destroy:116:3)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
        port: 80,
        address: '::1',
        syscall: 'connect',
        code: 'ECONNREFUSED',
        errno: -111,
          transitional: {
            silentJSONParsing: true,
            forcedJSONParsing: true,
            clarifyTimeoutError: false
          adapter: [ 'xhr', 'http' ],
          transformRequest: [ [Function: transformRequest] ],
          transformResponse: [ [Function: transformResponse] ],
          timeout: 0,
          xsrfCookieName: 'XSRF-TOKEN',
          xsrfHeaderName: 'X-XSRF-TOKEN',
          maxContentLength: -1,
          maxBodyLength: -1,
          env: { FormData: [Function], Blob: [class Blob] },
          validateStatus: [Function: validateStatus],
          headers: AxiosHeaders {
            Accept: 'application/json, text/plain, */*',
            'Content-Type': 'multipart/form-data; boundary=--------------------------751421172292702686143612',
            'User-Agent': 'axios/1.4.0',
            'Content-Length': '122615',
            'Accept-Encoding': 'gzip, compress, deflate, br'
          params: {
            method: 'openai-whisper',
            task: 'transcribe',
            language: 'en',
            encode: true,
            output: 'json'
          method: 'post',
          url: '192.168.0.18:9000/asr',
          data: FormData {
            _overheadLength: 159,
            _valueLength: 0,
            _valuesToMeasure: [Array],
            writable: true,
            readable: true,
            dataSize: 0,
            maxDataSize: 2097152,
            pauseStreams: true,
            _released: true,
            _streams: [Array],
            _currentStream: [DelayedStream],
            _insideLoop: false,
            _pendingNext: false,
            _boundary: '--------------------------751421172292702686143612',
            _events: [Object: null prototype],
            _eventsCount: 4
        request: <ref *1> Writable {
          _writableState: WritableState {
            objectMode: false,
            highWaterMark: 16384,
            finalCalled: false,
            needDrain: false,
            ending: false,
            ended: false,
            finished: false,
            destroyed: false,
            decodeStrings: true,
            defaultEncoding: 'utf8',
            length: 0,
            writing: false,
            corked: 0,
            sync: true,
            bufferProcessing: false,
            onwrite: [Function: bound onwrite],
            writecb: null,
            writelen: 0,
            afterWriteTickInfo: null,
            buffered: [],
            bufferedIndex: 0,
            allBuffers: true,
            allNoop: true,
            pendingcb: 0,
            constructed: true,
            prefinished: false,
            errorEmitted: false,
            emitClose: true,
            autoDestroy: true,
            errored: null,
            closed: false,
            closeEmitted: false,
            [Symbol(kOnFinished)]: []
          _events: [Object: null prototype] {
            response: [Function: handleResponse],
            error: [Function: handleRequestError],
            socket: [Function: handleRequestSocket]
          _eventsCount: 3,
          _maxListeners: undefined,
          _options: {
            maxRedirects: 21,
            maxBodyLength: Infinity,
            protocol: 'http:',
            path: '/192.168.0.18:9000/asr?method=openai-whisper&task=transcribe&language=en&encode=true&output=json',
            method: 'POST',
            headers: [Object: null prototype],
            agents: [Object],
            auth: undefined,
            family: undefined,
            lookup: undefined,
            beforeRedirect: [Function: dispatchBeforeRedirect],
            beforeRedirects: [Object],
            hostname: 'localhost',
            port: '',
            agent: undefined,
            nativeProtocols: [Object],
            pathname: '/192.168.0.18:9000/asr',
            search: '?method=openai-whisper&task=transcribe&language=en&encode=true&output=json'
          _ended: false,
          _ending: false,
          _redirectCount: 0,
          _redirects: [],
          _requestBodyLength: 122557,
          _requestBodyBuffers: [ [Object], [Object], [Object] ],
          _onNativeResponse: [Function (anonymous)],
          _currentRequest: ClientRequest {
            _eventsCount: 7,
            outputData: [],
            outputSize: 0,
            writable: true,
            destroyed: false,
            _last: true,
            chunkedEncoding: false,
            shouldKeepAlive: false,
            maxRequestsOnConnectionReached: false,
            _defaultKeepAlive: true,
            useChunkedEncodingByDefault: true,
            sendDate: false,
            _removedConnection: false,
            _removedContLen: false,
            _removedTE: false,
            strictContentLength: false,
            _contentLength: '122615',
            _hasBody: true,
            _trailer: '',
            finished: false,
            _headerSent: true,
            _closed: false,
            socket: [Socket],
            _header: 'POST /192.168.0.18:9000/asr?method=openai-whisper&task=transcribe&language=en&encode=true&output=json HTTP/1.1\r\n' +
              'Accept: application/json, text/plain, */*\r\n' +
              'Content-Type: multipart/form-data; boundary=--------------------------751421172292702686143612\r\n' +
              'User-Agent: axios/1.4.0\r\n' +
              'Content-Length: 122615\r\n' +
              'Accept-Encoding: gzip, compress, deflate, br\r\n' +
              'Host: localhost\r\n' +
              'Connection: close\r\n' +
              '\r\n',
            _keepAliveTimeout: 0,
            _onPendingData: [Function: nop],
            agent: [Agent],
            socketPath: undefined,
            method: 'POST',
            maxHeaderSize: undefined,
            insecureHTTPParser: undefined,
            joinDuplicateHeaders: undefined,
            _ended: false,
            res: null,
            aborted: false,
            timeoutCb: null,
            upgradeOrConnect: false,
            parser: null,
            maxHeadersCount: null,
            reusedSocket: false,
            host: 'localhost',
            protocol: 'http:',
            _redirectable: [Circular *1],
            [Symbol(kCapture)]: false,
            [Symbol(kBytesWritten)]: 0,
            [Symbol(kNeedDrain)]: true,
            [Symbol(corked)]: 0,
            [Symbol(kOutHeaders)]: [Object: null prototype],
            [Symbol(errored)]: null,
            [Symbol(kHighWaterMark)]: 16384,
            [Symbol(kRejectNonStandardBodyWrites)]: false,
            [Symbol(kUniqueHeaders)]: null
          _currentUrl: 'http://localhost/192.168.0.18:9000/asr?method=openai-whisper&task=transcribe&language=en&encode=true&output=json',
        cause: Error: connect ECONNREFUSED ::1:80
            at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1495:16) {
          errno: -111,
          syscall: 'connect',
          address: '::1',
          port: 80
      [14.09.2023 12:26.49.157] [ERROR] Whoops! There was an uncaught exception...
      [14.09.2023 12:26.49.158] [ERROR] TypeError: Cannot read properties of undefined (reading 'toLowerCase')
          at Class.stopRecording (/home/pi/MagicMirror/modules/MMM-WhisperGPT/node_helper.js:213:23)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      It seems that for some reason axios is sending the request to the localhost? I have setup whisper and mimic services in a different server
      • R
        rmonteroc
        Issue was related to the url of whisper and mimic, they should include http://
